EtherCAT is a popular industrial Ethernet technology for real-time automation control, offering high speed and reliability. Using CODESYS on a Raspberry Pi to manage EtherCAT I/O is a cost-effective and scalable solution for industrial automation projects. In this guide, we’ll walk you through the steps to set up EtherCAT I/O with CODESYS and a Raspberry Pi.
Conclusion
Setting up EtherCAT I/O on a Raspberry Pi with CODESYS opens up endless possibilities for industrial automation projects. The combination of affordable hardware and powerful software like CODESYS provides a robust platform for developing custom automation solutions. With the steps outlined in this guide, you should be able to set up and test your EtherCAT network successfully.
