project log
12/17/2024 at 11:05 • 0 commentsProject Logs:
December 11, 2024: Final Session
- Joystick Calibration: Joysticks calibrated for smooth movement. Arduino code written to handle analog inputs and control tank movement.
- Shooting Mechanism: Prototype finalized. Small DC motor propels cardboard projectiles with button activation. Arduino code enhanced to manage shooting.
December 3, 2024: Tank Design and Assembly
- Tank Assembly: Physical components finalized, ergonomic chassis designed for different players. Joysticks, shooting mechanism, and dashboard integrated.
- Shooting Mechanism Testing: Cardboard projectiles launched at a reasonable distance. Adjustments made for optimal launch force.
November 26, 2024: Shooting Mechanism Finalization & LED Integration
- Motor Upgrade: More powerful motor selected to ensure consistent projectile launch.
- LEDs: Soldered and integrated into the dashboard, programmed to indicate game status (e.g., shooting readiness, tank status).
November 19, 2024: Technical Problems and Solutions
- Motor and Launch Tube Adjustment: Issue with projectile launch fixed by using a stronger motor and improving launch tube design.
November 5, 2024: Initial Game Testing
- Testing: Joysticks and shooting mechanism were tested. Basic code written and visual/audio effects (e.g., buzzer for shooting) were implemented.
Next Steps:
- Finalize mechanical assembly and optimize shooting mechanism.
- Improve accuracy and design (motor adjustments, painting, and decorating the tank).
- Add more features (sound effects, extra LEDs, LCD screen for score/status).
- Conduct final testing to ensure system functionality and fun gameplay.
