Code Lock with ESP8266 (ESP32 should also work but is untested)
Hardware needed:
Wemos D1 Mini (ESP8266)
Some kind of electric lock.
A connected matrix keypad with digits 0 through 9, size 3x4.
The matrix is connected to pins D1 through D7:
D1 to D4 are connected to the rows.
D5 to D7 are connected to the columns.
A relay board to control the lock connected to D8.
Optional reed switch to detect unlocked/locked/door opened/closed connected to D0.
Additionally, a 5V power supply is required, such as from a USB charger.
Features:
WiFi connectivity but can run without network connection but chcking valid times will be a problem since ESP8266 has no RTC.
Admin web page.
MQTT connectivity for automations with Home Assistant or similar.
Supports 8 local individual codes, consisting of the digits 0 through 9,* and #, with a maximum length of 8.
Different codes can be valid at specific hours of the day.
Unlock the lock using the keypad by entering a valid code, or
unlock from admin page, or unlock from MQTT.
If "AlwaysOpenOn" is set, the lock will be unlocked all the time.
Automatically connects to an MQTT broker if one is configured.
Unlock and set AlwaysOpen from MQTT.
The program updates an MQTT server/topic with activity, including timestamps, who unlocked the door, commands published from MQTT and admin page, and input from the keypad.
You can text a temporary code to a customers mobile and validate the keypresses and unlock via MQTT, as an example. Optional detection when the lock/door is opened using a reed switch connected to D8. (Switch is detecting changes.)
Serial interface enabled in USB, 9600 baud.
OTA updates.
Wi-Fi Connectivity:
Configure initial Wi-Fi settings via a simple Access Point (AP) and a web page.
WiFi Settings are stored in non volatile memory.
Password-Protected Admin Web Page:
The admin page features:
A button to manually unlock the door.
A button to permanently put the lock in always-unlocked mode".
Managing codes, their validity periods, and comments/users. There is a button to delete configuration file if needed which at reboot will create the default config file.
Configuring the MQTT broker (address, username, password, topic).
If you have multiple doors, door names should be different, and MQTT topic should be descriptive for ease of identification.
Changing the admin password for the admin page.
Forget the WiFi settings which will create an Access Point for 60 seconds
Configuration Storage:
Configuration is saved in a JSON file on a non-volatile partition, ensuring it persists across reboots or firmware uploads.
A default configuration is created if no valid configuration file exists or if it becomes corrupted.
Default Settings:
Default code #1: 12345678 , Valid 24 hours around the clock
Default admin web page password: adminpass
Default door/lock/MQTT client name: Door NtpServer pool.ntp.org
TimeZone PST8PDT,M3.2.0,M11.1.0 See https://gist.github.com/alwynallan/24d96091655391107939 for details about TZ and DST
RelayPullTime 1000 (mS)
Known issues:
No https encryption on web page.
No TLS encryption for MQTT connection.
MQTT:
davedarko
Myles Eftos
Stefan-Xp
Integration with Home Assistant etc. is possible trough MQTT.
Since every keypad stroke is sent to MQTT, you can automate/compare codes to known numbers in a database or similar.
The CodeLock also subscribes and responds to valid MQTT commands like Open, AlwaysOpenOn, AlwaysOpenOff which makes it easy to have a door unlocked during business hours as an example.
