After making the world's clunkiest BLE key finder in https://hackaday.io/project/197894-the-worlds-clunkiest-key-finder, I now want to make the smallest one possible. This project will be both the hardware, with the gerbers of the PCB and BOM, and the firmware to run on it.
To make it even more challenging I will try to keep the BOM around 1€/$/£, to compete with the Asian economy of scale (which is kansloos, as we would say in the lower countries.)
This is my first project that requires designing a PCB, so it will be a lot of trial and error. Many Bluetooth SoCs have a minimal circuit design, which should make it a bit easier though.
I will start with the CH592, but will explore options that use a dedicated BLE tx chip + MCU combo as well like the Ci24R1.
Version 1 of the PCB is finished, and I ordered the first batch on PCBWay which they kindly offered to sponsor! I'll be doing a review of the boards when they arrive.
I've changed the MCU from CH592 to CH591, since they were a lot cheaper! The BOM is now around $0.5 in quantity 20 to 30, depending a bit on which fab house you choose. The final PCB is only 11x11 mm, which is probably maybe the smallest BLE module on the planet :)
