• Kinda geting it
    GthiNa day ago 0 comments
    I started o write encoders and decoders for common protocols like CAME, and NICE. Which are working, so now, i trying to make the filter of the signal.
  • IR blaster goes overdrive
    GthiN01/19/2025 at 23:58 0 comments
    After some fails i found  performance/skill issue sweet spot in form of BC556 transistors, and finally have IR blaster send to overdrive. I utilize classic form IR led on which i measure around 0.8 A, and "1W 160 degrees" IR led on which i measure around 2A (i cant really measure that precisely since keeping it just power on cause death of small LED or BC556 -> intended, when it started burn, i take step back...)
    *FW is in kinda mess, i need to clean that ASP.
  • Replay of car keys
    GthiN01/15/2025 at 13:16 0 comments
    I updated subGHZ part, so i can now use custom settings instead of presets, and even replay cheap chinesse aftermarket keyfobs
