Kinda geting it
a day ago • 0 commentsI started o write encoders and decoders for common protocols like CAME, and NICE. Which are working, so now, i trying to make the filter of the signal.
IR blaster goes overdrive
01/19/2025 at 23:58 • 0 commentsAfter some fails i found performance/skill issue sweet spot in form of BC556 transistors, and finally have IR blaster send to overdrive. I utilize classic form IR led on which i measure around 0.8 A, and "1W 160 degrees" IR led on which i measure around 2A (i cant really measure that precisely since keeping it just power on cause death of small LED or BC556 -> intended, when it started burn, i take step back...)
*FW is in kinda mess, i need to clean that ASP. -
Replay of car keys
01/15/2025 at 13:16 • 0 commentsI updated subGHZ part, so i can now use custom settings instead of presets, and even replay cheap chinesse aftermarket keyfobs
