Opto Box v2
A versatile device for optogenetic manipulations in groups of flies
Public Chat
0 followers
The opto-box is a device for optogenetic activation or silencing in groups of adult fruit-flies. It has an Arduino at its heart which controls a number of WS2812B RGB LEDs. It uses off the shelf components and (almost) fully 3D printed. Ignoring the print times the device can be assembled over a weekend. It represents a significant improvement (not just in terms of looks) over an earlier iteration. The device can function as a standalone unit once the user inputs(colour of light, intensity, frequency, duration) have been input through the serial monitor.
Introduction
Optogenetics is the use of light to control some aspect of biology in a living system. My previous project gives a short intro on how this tool is leveraged in Drosophila especially in the context of neuroscience research so I will not go into that here. The reason for building this device was that there were no commercial solutions to our problem. In the lab, we study the role of sleep in memory consolidation(among other things). Our memory assays use groups of flies and that means we have to perform optogenetic manipulations uniformly in as many as 100 flies per vial. To my knowledge there are no commercial systems that do this. This is where the Opto Box comes in. Here is the first iteration of it.
There are slots for 5 x 2 standard drosophila culture vials and each is illuminated by two LED modules(one on either side). They are equidistant from the center of the vial so all flies receive roughly equal illumination. It uses a separate 5V power supply for the lights. The BNC connector is to prevent accidental swapping with the 9V supply for the Arduino which would fry the lights. The v2 uses only one input.
The v2 is also more modular. It is not shoddily held together with hot glue like its predecessor and things can be replaced if the need arises.
Both of them use the WS2812B LEDs. These come in a variety of forms- single SMD chips, strips, circular modules, 8x8 squares, 8 in-line straight modules, there is even a flexible one. I used the 8 LED straight module as this gives ample coverage over the region of the culture tube (excluding the media and the plug). These are RGB LEDs so they can be used with different optogenetic effectors like Chrimson(Red), channelrhodopsin (blue), or GtAcRs(green) although we have only tried it with Chrimson and GtAcR1. Another benefit is that these can be daisy chained and it is possible to hook up multiple of these modules in series. There is a nice FastLED library for Arduino written by Daniel Garcia that makes controlling the LEDs very easy. The intensity, colour, switching on/off can all be done by software unlike regular RGB leds. This eliminates the need for a complicated circuity. The downside is that the intensity is lower than that of 12V RGB leds so it might not work for some applications. We haven't measured the actual light output with a probe because we do not have a probe that is small enough to fit inside.
Operation
The Opto Box is hooked up to a 9V or 12V 2A DC adapter. The power indicator should light up and there is an initial beep. This should be done before connecting the Arduino to the computer. The Arduino inside is then connected to a laptop. Inputs are given through the serial monitor of the Arduino IDE. Once the programming is done the laptop can be disconnected. Make sure that the power indicator is on before starting the stimulation . If the stimulation starts without external power, the Arduino will try to power the LEDs on its own which might damage components on the board. (Maybe the v3 will not have this problem!)
FastLED-3.7.0.zip
FastLED library by Daniel Garcia. In case it becomes unavailable in the future.
x-zip-compressed - 525.32 kB - 01/05/2025 at 12:32
Download
WS2812B.pdf
WS2812B datasheet
Adobe Portable Document Format - 347.03 kB - 01/05/2025 at 10:06
Preview
Opto_Box.ino
Arduino Sketch
ino - 8.49 kB - 01/05/2025 at 09:36
Download
STL files.zip
For 3D printing
x-zip-compressed - 363.38 kB - 01/05/2025 at 09:35
Download
Fusion360 Files.zip
Autodesk design files
x-zip-compressed - 17.46 MB - 01/05/2025 at 09:33
Download
  • 1 × Arduino Uno r3
  • 20 × WS2812B straight 8 LED module Lots of counterfeits on the market these days. Double check and order a few extra
  • 1 × DC-DC 3A 5V-12V to, 5V Step-down Power, Supply Module
  • 1 × Barrell Jack 2.2x5.5 Female
  • 4 × Countersunk Philips Head M3 X 10 mm Screw
View all 23 components
  • Circuitry
    Wriju • 01/05/2025 at 14:13 • 0 comments
    The WS2812B leds are daisy chained in each panel. Since there are four of these panels, they all share the data line. The Arduino "thinks" there are only 40 leds(8x5) but in fact there are 120. The reason for not connecting the panels linearly(thereby daisy chaining all 120 leds) is to reduce communication time. Instead, the connections branch off to the four panels i.e. the wires connect to a screw terminal block on the perfboard.. We do not need the leds to be individually addressable but if all of them are connected linearly then the last (120th) led will take a significant amount of time to respond and this might be an issue when using high stimulation frequencies.
    All the peripheral components(indicator leds, buzzer, and cooling fans) are connected to the perfboard. The fans are switched through a transistor since the Arduino itself cannot power two such fans for circulation.
    This is a schematic of the circuit.
  • 3D printed parts
    Wriju • 01/05/2025 at 13:54 • 0 comments
    The device is mostly 3D printed. All parts expect the foot pads were printed in PLA+ on a MakerBot MethodX. The foot pads(not shown) were printed in TPU.
     All parts expect the light housing panels are straightforward. The panels (shown below) were printed with the side facing the vials up such that these were smoother and hence more reflective. The breakaway supports are a bit tedious to clean.  I would recommend a lower layer height (0.1mm) and a somewhat higher infill (25% or more) to ensure that the part does not snap while removing the supports.
View all 2 project logs
