BEZICRON
A 3dprinted electro-mechechical clock with flexible digits
Inspired from the hair rubber band of my daughter I created a mechanical clock which stretches a flexible elastic borrowed from a flexible pen to make the digits. The arms are moved by cams which stretches the elastic band to make the digits. Each digit approximately measures 50mmx 55 mm. The entire clock is about 300 x 140 x 150mm
The clock consists of  4 modules of digits paired in two units. Each pair is powered by  a 20mm geared stepper motor. Each pair has one module driven by the stepper motor and the second module is moved by a carryover mechanism.  Both the units are controlled by a control board in the base containing a atmega8 running in the arduino ecosystem.
The single module
The entire assembly of 4 modules
The base
It contains the control board which consists of a Atmega 8 and a pair of a4988 stepper drivers
the complete drawing
  • 1 × Atmega 8 microcontroller
  • 2 × A4988 Power Management ICs / Motion, Motor and Servo Control
  • 3 × A3144 hall sensor
  • 2 × push buttons
  • testing a dual module with carryover
    ekaggrat singh kalsi • 01/10/2025 at 05:51 • 0 comments
    next I assemble a dual module to test the carryover mechanism. I worked smoothly as the 20mm geared stepper is a overkill for this purpose. The units motor homes to zero using the hall sensor and then runs clockwise to change the digits. After every one turn it carryovers to the tens module using a carryover gear mechanism.
  • testing a single module
    ekaggrat singh kalsi • 01/10/2025 at 05:47 • 0 comments
    I built a single module to test the concept. The module was driven by a geared 15mm stepper motor which was controlled by a cnc shield. I quickly realized that the torque need to turn the cams and followers was much more than I anticipated. The 15mm motor ran very hot and overworked. So in the next iteration I used 20mm geared stepper motors
View all 2 project logs
ComputerL wrote 08/27/2026 at 18:27 • point
Hey, are you still planning on selling the design files? If not I'd love to download them for free! This is a great project you made by the way. Thank you!
Ben Norris wrote 09/28/2025 at 17:39 • point
Now we just need elasticated EL wire
ekaggrat singh kalsi wrote 09/29/2025 at 05:02 • point
ya waiting for that. Sadly it has a copper base which wont expand or contract and the led cob filaments are too flexible to make a spring.
Bertrand Selva wrote 09/12/2025 at 15:51 • point
C'est très beau : beautiful !!
Makerinator wrote 09/11/2025 at 19:16 • point
THIS IS SO COOL! Is the material for the numbers something you could potentially change? If you made it a glow-in-the-dark or black-light reflective material that would look really neat!
ekaggrat singh kalsi wrote 09/12/2025 at 00:11 • point
i looked for many but currently these pen cables are the only durable ones. the think is currently it drags in the loops that hold it and i dont know how even this could last longer. i dont have the time now to long duration test many materials. Maybe sometime in the future
Makerinator wrote 09/12/2025 at 14:10 • point
Gotcha. Still a very cool project! :)
Alexander wrote 09/11/2025 at 18:54 • point
Is this under any sort of open hardware license? I'm not that experienced with CAD and I'd love to be able to look at the design files and see how everything attaches together a bit more closely.
ekaggrat singh kalsi wrote 09/12/2025 at 00:12 • point
sorry but I intend to make it a product in the future so it needs a proper patent or design registration . I have other ones that are free to use
Alexander wrote 09/12/2025 at 00:18 • point
There are many open hardware products out there! Being open source doesn't affect your ability to sell it :)
Ben Norris wrote 09/28/2025 at 17:42 • point
Unfortunately you can't patent something once you've already made it publicly known, it is no longer novel
Fred wrote 09/10/2025 at 16:17 • point
Wonderful and so creative. Thank for you hard work on this.
ekaggrat singh kalsi wrote 09/10/2025 at 23:17 • point
thanks a lot for your kind words
Ruth Anne wrote 09/10/2025 at 07:28 • point
Wonderful! I am fascinated!
thanks !
curiousmarc wrote 07/30/2025 at 15:45 • point
Excellent!
Leizar06001 wrote 01/15/2025 at 14:52 • point
Nice ! You might be able to use a material that can slide through rings and be straighten by gravity or a spring
ekaggrat singh kalsi wrote 01/16/2025 at 07:18 • point
that is a great idea. i will try silicone led strings pulled by a spring. I need to somehow hold it on the arms and let it slide
nologolon wrote 01/13/2025 at 13:45 • point
Great idea!
Imagine you could bend the luminous rubbery led filaments also.
Would look great in the dark.
ekaggrat singh kalsi wrote 01/14/2025 at 02:11 • point
yes I thought about them but they cant stretch and cant be coiled to make a spring like band, Still looking for a material that can do that
Dan Maloney wrote 01/10/2025 at 19:46 • point
Great build, love the design! I can see how you probably played with those hair ties and made a few crude digits with your fingers and got the idea for this. Wrote this up, should publish soon. Thanks for another unique clock!
ekaggrat singh kalsi wrote 01/11/2025 at 01:05 • point
thanks a lot for publishing it!
Ken Yap wrote 01/10/2025 at 06:19 • point
👍 Haha this is cool.
ekaggrat singh kalsi wrote 01/10/2025 at 08:14 • point
thanks!
thanks
