The clock consists of 4 modules of digits paired in two units. Each pair is powered by a 20mm geared stepper motor. Each pair has one module driven by the stepper motor and the second module is moved by a carryover mechanism. Both the units are controlled by a control board in the base containing a atmega8 running in the arduino ecosystem.
The single module
The entire assembly of 4 modules
The base
It contains the control board which consists of a Atmega 8 and a pair of a4988 stepper drivers
the complete drawing
Richard
Pattern Agents
Hey, are you still planning on selling the design files? If not I'd love to download them for free! This is a great project you made by the way. Thank you!
