modular_case_for_lora_tbeam.scad
Parametric OpenSCAD file. You can use this file to customise the mount, or you-know, make any changes you want. Open source!
scad -
43.97 kB -
02/04/2025 at 04:49
Download
modular_case_tbeam_back_var0.stl
No mounting features
Standard Tesselated Geometry -
760.74 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var1.stl
slots at each end
890.44 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var2.stl
open slots at each end
999.08 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var3.stl
triangle rings at each end
915.00 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var4.stl
slot at one and and a ring at the other
904.70 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var5.stl
38mm slots (for 1.5" web) on each side
879.38 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var6.stl
open 38mm slots (for 1.5" web) on each side
985.10 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var7.stl
two 25mm slots on each side with 38mm spacing. This can be attached horizontally to molle webbing
989.42 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_back_var8.stl
two 25mm slots on each side with 50mm spacing. This can be attached vertically to molle webbing directly by hooking into the molle grid.
1.18 MB -
01/30/2025 at 09:14
Download
modular_case_tbeam_clam_bottom_antvar0.stl
351.43 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_clam_bottom_antvar1.stl
351.41 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_clam_bottom_antvar2.stl
352.56 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_clam_top_antvar0.stl
550.56 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_clam_top_antvar1.stl
552.16 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_clam_top_antvar2.stl
723.04 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_front_antvar0.stl
425.52 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_front_antvar1.stl
431.37 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_front_antvar2.stl
551.69 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_side.stl
422.65 kB -
01/30/2025 at 09:14
Download
modular_case_tbeam_buttons.stl
191.26 kB -
01/30/2025 at 09:14
Download
