Step 1: Install and setup this apps
- FrerCAD and KiCAD is needed
- Open FreeCAD, make sure KicadStepUP work add-on is installed.
- Make sure the 3D files of the parts(resistor , IC etc.) in the PCB that you want to make fixture of showing up correctly in the 3D viewer by going View>3D viewer in KiCAD.
Step 2: Build the Fixture PCB Project in Kicad
Build the fixture PCB project
- First make an empty project in the KiCad.
- In the PCB editor window make a closed shape in the Edge.cut layer on the layer menu on right panel and save it.
- remember to close the this file in the KiCad.
Step 3: Create the Outline of the Parts
- First open the that you want to make fixture of in the FreeCAD using menu File>Import and select the PCB file like in the pic.
- Then import the fixture PCB in the step 2.
- After the import is finished, locate the PCB_Sketch_xxx file on the Model panel in the FreeCad, like shown in the pic.
- Double click to edit it, and make the part fixture outline. mine shown in the pic.
Step 4: Push the New PCB Outline to the PCB File
Select the PCB_Sketch_xxx file and select the Push Sketch to PCB option and select the PCB file that created in the step 2. Just go with the default outline.
Step 5: Order the PCB
Now open PCB file created in the step 2 in the KiCad.
The new PCB outline made in the FreeCad in step 3 should show up now.
Now export the gerber file and order the PCB as usually from PCB fab. I used PCBWay, you can use me promotional link to order yours.
Remember to use no coper layer as shown in the pic, PCBWay will look into the file and give you a quote, easy.
Step 6: Using the Fixture to Solder
Here is the custom fixture for my mutantC v5 PCB.
- I pre-applied the solder on the pads
- put the fixture on top of the PCB and used tape to fix it so it won't move
- put down the parts of inside the cut out
- then used the hot-plate to melt the solder and used flux also.
- now after solder is done, removed the fixture and cleaned the PCB, and checked the solder
rahmanshaber
Budi Prakosa a.k.a Iyok
mbsg99
youkito1991
Thanks for letting others know, had a great trouble to solder those connectors in parallel
