I started with motor driver circuit. As the steering motor is so small and cannot handle too much current I needed to find a stepper driver with sense input. Second neccessary character is low voltage operation. 2.7V-15V is suitable for this project.
Second circuit is about USB input for charging and programming
To be on the safe side there needs to be a USB to serial converter:
For MCU I chose ESP32S2 MINI as it has enough I/O for this project
Power is handled by main switch
And a TP4056 is chosen for charger
3.3V linear regulator for ESP32
And simple battery level measuring input
Missing are some LEDs and buttons. To make some noise I chose this piezo buzzer. Porbably I should make some calckulations on the drive power for that.
Lauri
