The heart of the entire cyberdeck is the RPi4 with a massive passive heatsink, complete with a fan. The fan is switched on and off by the RPi itself based on temperature using a GPIO pin and a simple transistor switch.
The main DC converter that generates 5.3V from the battery voltage to power most components. A voltage divider for monitoring battery voltage and an ACS712 module for current measurement are connected to the input.
