TFT28-Frame.stl
A little frame to hold the TFT in place, because the glue it comes with doesn't hold up well. Melt the studs when the frame is in place.
Standard Tesselated Geometry - 39.14 kB - 05/27/2025 at 13:09
Download
BS500 Bezel.stl
The little Bezel for use around the navigation buttons. Print it yourself. Ready to slice.
Standard Tesselated Geometry - 113.46 kB - 05/27/2025 at 13:08
Download
Main schematics
Bitmap Image File - 3.99 MB - 05/15/2025 at 06:49
Preview
USB interface and power supply/charging circuit schematics
Bitmap Image File - 3.77 MB - 05/14/2025 at 08:21
Preview
TFT display level shifter and power supply schematics
Bitmap Image File - 3.76 MB - 05/14/2025 at 08:19
Preview
TechScanOne_RevG_BS500.csv
BOM for the circuit board - hopefully all parts are correct, use at your own risk (like this entire project)...
ms-excel - 2.13 kB - 05/12/2025 at 08:49
Download
TechScanTopV5.stl
The top half of a suitable enclosure for the circuit board. Version 5. Ready to slice.
Standard Tesselated Geometry - 726.94 kB - 05/09/2025 at 15:18
Download
TechScanBottomV5.stl
The bottom half of a suitable enclosure for the circuit board. Version 5. Ready to slice.
Standard Tesselated Geometry - 580.26 kB - 05/09/2025 at 15:17
Download
BootloaderAPI.pdf
This is the documentation for the bootloader that needs to programmed on the board, including the API documentation for writing apps.
Adobe Portable Document Format - 1.45 MB - 05/09/2025 at 15:15
Preview
HowToBuild.pdf
This is an illustrated PDF describing Step-by-Step how to put everything together.
Adobe Portable Document Format - 2.72 MB - 05/09/2025 at 15:08
Preview
