HivesLink : Pollen Pathway
A Sweet:Sister Project to my Eurorack VinesLink Module
Starting from
has orders / reviews
Ships from
HivesLink is the External Adaptor that helps Eurorack users get into the collaboration grooves.
This Device allows you to Patch CV/Audio Signals from 3.5mm Jack's across Cat6/RJ45 cables to other Vines Link modules allowing collaboration between eurorack systems with the addition of labels you can be in sync with others or be pleasantly surprised of the randomness.
~Features~
• Patch CV/Audio Signals from Eurorack Jack's across Cat 6 cables too other Vines Link modules allowing collaboration of sounds between systems.
• Incoming Sounds are Displayed by LEDs  for a Visualising Signals. The LEDs are lit by the incoming systems power. They are wired to the Jacks internal Switch so when they are plugged in they are disconnected so there is no voltage drop to Signals.
• Label Jacks on the Silkscreen for Signal types
• Use the Numbering System for other types of collaborations
Schematic_Pollen-Pathway-Hive-Link_2025-03-27.pdf
Adobe Portable Document Format - 46.84 kB - 03/27/2025 at 22:34
Preview
  • Some Photos of the First Assembled Prototype.
    Neil Mundt • 03/16/2025 at 20:53 • 0 comments
  • Blender PCB Animation
    Neil Mundt • 03/01/2025 at 21:36 • 0 comments
  • The Artwork Is pretty Much Complete now
    Neil Mundt • 02/24/2025 at 17:07 • 0 comments
    Really Glad I went with Honey Drip as a theme. Sometimes less is more it kinda was getting (Hexagon galore) before, but I think it adds quite a bit to it. Really looking forward to getting some to test. This one is going to be THT components because they are easier to solder and handle. My VinesLink Module is nice using the SMD components. But they can get a little Fiddly. I could add a optional SMD var-taint since I have the footprint and adding it would not be much extra work.
  • Panel Artwork is Almost Done
    Neil Mundt • 02/23/2025 at 03:10 • 0 comments
    It is just going to be 2 PCB sandwiched together as a standalone unit. It will be Textured with hexagons on one of the copper layers. Similarly like my Vines Link Module. I think it Turned out pretty great. Looking forward to get some prototypes soon. Until then I got some more modules to assemble. Added the Silkscreen Hexagons Last Minute and I think the layout is decent for Labelling like VinesLinks. Might aswell have it as a option to save someone the hassle of using tape. Also Would like to mention the Front Used is Honey Dripper By someshinzz I was thinking for using a Hexagon Font but some of the Numbers were hard to tell what they were.
View all 4 project logs
