Two Bar Vertical Lift Mechanism.
A Scotch Yoke type mechanism requiring less horizontal space.
In this model, a 160mm vertical lift is achieved will requiring 80mm horizontal space. A typical Scotch Yoke mechanism requires twice the same horizontal space as the vertical movement.
Videos of the mechanism design and assembly are here:
https://youtu.be/_f6hMy-qdPI
https://youtu.be/pM3QrJ5zh44
Robin Dorst wrote 03/21/2025 at 14:16 point
Very interesting mechanism. Where would something like this be used and where did you get the inspiration for this project?
Greg Zumwalt wrote 03/21/2025 at 19:33 point
The mechanism would primarily be used as a scotch yoke replacement requiring half the horizontal space.  The inspiration for the model came from a follower / friend who sent me a video of a model and asked if I could recreate it.  Here's a link to a video of my recreation of the model:               https://youtu.be/Uv1PeOPVsBo
Greg
Greg Zumwalt wrote 03/19/2025 at 16:22 point
Thank you very much peter, I'm glad you enjoyed it!
Greg
peter jansen wrote 03/19/2025 at 03:01 point
cool!
