The main body is laser cut 3.4mm plywood stained dark with a coat of spray matte poly finish.
The speaker grill is some random fabric also laser cut to shape.
The diffuser for the LED is 3D printed in a matte gold PLA.
The 3.2 VDC LED leads are soldered directed to the 2 pin header.
It's all held together and insulated with low temp hot snot glue.
That's it.
I am considering trying to make it into a mini Bluetooth speaker.
