POLOLU-2820.pdf
Datasheet of the Servo-Motor FS90R
Adobe Portable Document Format - 92.12 kB - 05/07/2025 at 11:40
Preview
0900766b814b241f.pdf
Datasheet of the L7805CV
Adobe Portable Document Format - 1.12 MB - 05/07/2025 at 11:38
Preview
Li-ion 7.4V.pdf
Datasheet of the Li-ion 7.4V
Adobe Portable Document Format - 679.51 kB - 05/07/2025 at 11:34
Preview
Motor gear N20.pdf
Datasheet of the Motor gear N20
Adobe Portable Document Format - 718.67 kB - 05/07/2025 at 11:32
Preview
drv8833.pdf
Datasheet of the DRV8833
Adobe Portable Document Format - 949.51 kB - 05/07/2025 at 11:27
Preview
pico-w-datasheet.pdf
Datasheet of the Raspberry Pi Pico W
Adobe Portable Document Format - 18.89 MB - 05/07/2025 at 11:25
Preview
Worm_Drive.STL
Standard Tesselated Geometry - 1.61 MB - 05/07/2025 at 10:59
Download
Stop_Syringe.STL
Standard Tesselated Geometry - 25.08 kB - 05/07/2025 at 10:57
Download
Support_Syringe_V2.STL
Standard Tesselated Geometry - 51.74 kB - 05/07/2025 at 10:55
Download
Propeller.STL
Standard Tesselated Geometry - 281.33 kB - 05/07/2025 at 10:51
Download
Gear24_Tooth .STL
Standard Tesselated Geometry - 4.94 MB - 05/07/2025 at 10:50
Download
Gear8_Tooth.STL
Standard Tesselated Geometry - 39.93 kB - 05/07/2025 at 10:49
Download
Rail1_Syringe.STL
Standard Tesselated Geometry - 121.96 kB - 05/07/2025 at 10:45
Download
Rail2_Syringe.STL
Standard Tesselated Geometry - 121.96 kB - 05/07/2025 at 10:44
Download
Axle_Syringe.stl
Axle between the two gears
Standard Tesselated Geometry - 80.68 kB - 05/07/2025 at 10:10
Download
Rails_Syringe.STL
Rails for the translation
Standard Tesselated Geometry - 39.93 kB - 05/07/2025 at 10:09
Download
Circle-Cover.stl
This document is the internal cover to close the tube
Standard Tesselated Geometry - 22.74 kB - 05/07/2025 at 08:29
Download
