CSignalView.h
Heaster file for the CSignalView class, which is also used in the Propeller Debug terminal application. See CSignalView.cpp for implementation.
plain - 3.10 kB - 08/19/2025 at 11:45
Download
CSignalView.cpp
If you are creating an MFC application from scratch, and you want to implement some functionality such as rendering to a compatible offscreen bitmap, clipboard, or printer support, then you will need this file or something similar to help handle most of the things that go on "under the hood" with those tasks.
plain - 9.42 kB - 08/19/2025 at 11:41
Download
euclid.cpp
This is the stuff that you are probably interested in if you are serious about doing Euclidean geometry from scratch. It is easy to imagine that this could at some point, become a library for more general use inside Processing, according to the licensing model for that project. Enjoy!
plain - 39.18 kB - 08/18/2025 at 21:02
Download
euclid.h
Header file for Euclid.cpp. You will need to adapt this according to your environment, i.e., Processing, Unreal Engine, Blender, or maybe even your very own favorite DOOM wad editor, or whatever. GNU/MIT license. Enjoy!
plain - 8.12 kB - 08/18/2025 at 21:02
Download
