Unless a more comprehensive Navien component for ESPHome arises, I'll stick with the pure YAML approach, which is what I'm doing right now. I started with the approach seen in https://github.com/evanjarrett/ESPHome-Navien/blob/main/navien.yaml, but I made several functional and stylistic changes. That starting YAML is great for the reverse engineering task, but it's a bit cluttered for a more refined interface.
The ESPHome UART bus component is intended to be used as plumbing by other components. In the pure YAML case, there is no other component. The UART bus debug configuration (unrelated to DEBUG logging level in ESPHome) gives direct access to the underlying I/O buffer. That is just right for extracting information and updating template sensors based on that data. Luckily, the RS485 packets for the Navien are newline-delimited, which lines up with how the UART bus debugging wants to see things.
This is the configuration part of the uart block (doesn't include the decoding logic in the lambda, which I'll describe later):
uart:
tx_pin: 19
rx_pin: 22
baud_rate: 19200
data_bits: 8
stop_bits: 1
parity: NONE
debug:
direction: BOTH
dummy_receiver: True
after:
delimiter: "\n"
sequence:
- lambda: |-
UARTDebug::log_hex(direction, bytes, ' ');
UARTDebug::log_int(direction, bytes, ' ');
When DEBUG logging is enabled in the overall configuration, all RS485 packet bytes are logged as hex and decimal values. I changed the delimiter to a space because I find that easier to read.
[10:56:54][D][uart_debug:114]: <<< F7 05 50 0F 90 2A 45 00 0B 01 0C 02 17 00 62 5D 28 00 00 00 00 05 00 00 CB 14 00 00 2C 02 E7 08 B1 50 14 00 E0 01 00 00 00 00 AA 48 00 00 00 00 58 F7 05 50 50 90 22 42 00 00 05 49 62 5D 2C 00 00 00 00 00 00 A0 BE 00 20 00 00 00 00 E0 01 01 00 00 02 B9 00 00 00 00 00 5A
[10:56:54][D][uart_debug:176]: <<< 247 5 80 15 144 42 69 0 11 1 12 2 23 0 98 93 40 0 0 0 0 5 0 0 203 20 0 0 44 2 231 8 177 80 20 0 224 1 0 0 0 0 170 72 0 0 0 0 88 247 5 80 80 144 34 66 0 0 5 73 98 93 44 0 0 0 0 0 0 160 190 0 32 0 0 0 0 224 1 1 0 0 2 185 0 0 0 0 0 9
I mainly adopted the decoding techniques and names from https://github.com/dacarson/NavienManager/blob/main/Navien.cpp, though I temporarily gave the sensors IDs and names prefixed with "dc_". For tidiness and performance reasons, I removed things that did not yet have an interpretation. Where things appeared to be booleans, I made them template binary sensors instead of template numeric sensors. For the controller and panel version information, I made them template text sensors (though they don't completely match what I see on the water heater's display). For the sensors I'm currently observing, I took them at face value, though I am pretty sure some of them are either wrongly decoded values or are misinterpreted as the wrong kind of information; that will be sorted out in a later step. For now, I am avoiding doing conversions of things like centigrade to Fahrenheit, though I do the trivial sorts of conversions needed for the Navien-specific conventions.
The structure of the code generated by ESPHome is mostly a large and sophisticated polling loop. Best practice is to avoid any long delays in a synchronously executing component. In fact, if anything takes longer than 30 ms, a warning is written to the console. I'm not sure what happens in practice, but in theory some timing-based operations could be delayed or missed. There are two sources of delay in the UART bus debugging section. First, the very act of using the UART logging methods (with nothing else) is enough to bring the timing to 50-60 ms. That can be easily suppressed by setting the overall logging level to something less verbose than DEBUG. I typically use INFO for otherwise-chatty stable code. Second, the logic for decoding the bytes and publishing updates to the template sensors can add another 100 ms or so if DEBUG logging is enabled, though only about 20 ms without DEBUG logging. The decoding time is insignificant, and it's the sensor publishing that takes most of that time.
To make the UART debugging code as fast as possible, I moved all of the decoding and sensor publishing logic into separate ESPHome scripts. There are scripts for "water" packets, "gas" packets, and another for unrecognized "other" packets. (I later eliminated the separate script for "other" packets.) Simply moving things to scripts doesn't itself accomplish anything for the timing. I configured those scripts as mode "parallel", which I think makes them run asynchronously. A nice side effect is that the water and gas scripts can be running at the same time, and the UART can also be reading the next packet at the same time. To prevent obtaining inconsistent data from the UART buffer, I copy the bytes to a dedicated buffer for each script.
I configured each script to have a single running instance. I'm not sure what happens if a second instance is attempted, but I suspect it's treated the same as single mode, where there is a console message and the second instance is not run. That would mean missing some updates transmitted to Home Assistant. I had a plan for dealing with that, though I've been lazy and didn't implement it. The idea would be to check to see if the script is running and stop it before executing the new instance. That would mean that the stopped instance would only be partially through its logic. Since the bulk of the time is taken up in sensor update publishing, put all of those at the end of the script (already done), and put them in order of decreasing importance. Some sensor values are either constants or change so seldom that they are approximately constant. Those values don't go over the wire to Home Assistant very often. It would be possible to also implement logic that only did the ESPHome internal publishing periodically. That periodic update could apply for other reasons. For example, there is a figure for cumulative total gas consumption. That changes rapidly when water is being heated, but it wouldn't make much difference if the updated total were only shown every few seconds. The "gas" packets come pretty rapid-fire when the water is actually being heated.
Here is the YAML as it currently stands:
# https://hackaday.io/project/202744-calling-for-hot-water-the-recall
substitutions:
node_name: hotbuttonrelay-al
RELAY: 'GPIO26'
LED: 'GPIO27'
BUTTON: 'GPIO39'
UART_TX: 'GPIO19'
UART_RX: 'GPIO22'
log_level: 'INFO'
esphome:
on_boot:
then:
# delay to allow other boot time stuff to settle down
- delay: 5s
- script.execute: set_led_cold
esp32:
board: m5stack-atom
framework:
type: arduino
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
power_save_mode: high
fast_connect: on
manual_ip:
static_ip: !secret hotbuttonrelay-al_ip
gateway: !secret wifi_gateway
subnet: !secret wifi_subnet
dns1: !secret wifi_dns1
dns2: !secret wifi_dns2
logger:
level: ${log_level}
globals:
# We use these so that we don't have to share the UART receive
# buffer among scripts.
- id: water_packet_bytes
type: std::vector<std::uint8_t>
- id: gas_packet_bytes
api:
encryption:
key: !secret hotbuttonrelay-al_apikey
reboot_timeout: 60min
services:
- service: set_led_hot
then:
- logger.log:
tag: 'hotbutton'
level: INFO
format: "service: set_led_hot"
- script.execute: set_led_hot
- service: set_led_cold
then:
- logger.log:
tag: 'hotbutton'
level: INFO
format: "service: set_led_cold"
- service: set_led_off
then:
- logger.log:
tag: 'hotbutton'
level: INFO
format: "service: set_led_off"
- script.execute: set_led_off
ota:
platform: esphome
password: !secret ota_password
switch:
- platform: restart
- platform: gpio
pin: '${RELAY}'
restore_mode: ALWAYS_OFF
icon: mdi:hot-tub
on_turn_on:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
- delay: 500ms
- switch.turn_off: i_relay
- light.turn_off:
light:
- platform: fastled_clockless
chipset: SK6812
pin: '${LED}'
num_leds: 1
rgb_order: GRB # required
default_transition_length: 0s
icon: mdi:led-on
effects:
- pulse:
transition_length: 0.25s
update_interval: 0.25s
min_brightness: 20%
max_brightness: 99%
uart:
tx_pin: ${UART_TX}
rx_pin: ${UART_RX}
baud_rate: 19200
data_bits: 8
stop_bits: 1
parity: NONE
debug:
direction: BOTH
after:
delimiter: "\n"
sequence:
- lambda: |-
if (
bytes[0] == 247
&& bytes[1] == 5
&& bytes[2] == 80
&& bytes[3] == 80
&& bytes[4] == 144
&& bytes[5] == 34) {
id(water_packet_bytes) = bytes;
id(decode_water_packet)->execute();
else if (
bytes[0] == 247
&& bytes[1] == 5
&& bytes[2] == 80
&& bytes[3] == 15
&& bytes[4] == 144
&& bytes[5] == 42) {
id(gas_packet_bytes) = bytes;
id(decode_gas_packet)->execute();
} else {
id(decode_other_packet)->execute();
text_sensor:
- platform: template
binary_sensor:
# Local test button. This goes through the relay logic,
# so it's not an analog press of the water heater button.
- platform: gpio
pin:
number: '${BUTTON}'
inverted: true
mode:
input: true
filters:
- delayed_on: 10ms
- delayed_off: 10ms
sensor:
accuracy_decimals: 0
unit_of_measurement: °C
accuracy_decimals: 1
unit_of_measurement: LPM
script:
- id: set_led_hot
then:
- delay: 600ms # give the relay blink a chance to show
- light.turn_on:
red: 100%
green: 60%
blue: 0%
effect: fast_pulse
- id: set_led_cold
then:
- light.turn_on:
color_brightness: 20%
red: 0%
green: 0%
blue: 100%
effect: none
- id: set_led_off
then:
- light.turn_on:
color_brightness: 0%
red: 0%
green: 0%
blue: 0%
effect: none
- id: decode_water_packet
mode: parallel
max_runs: 1
then:
- logger.log: "Navien WATER packet ^^^^"
- lambda: |-
std::vector<uint8_t>& bytes = id(water_packet_bytes);
byte w_system_power = bytes[9];
byte w_flow_state = bytes[8];
byte w_set_temp = bytes[11];
byte w_outlet_temp = bytes[12];
byte w_inlet_temp = bytes[13];
byte w_system_status = bytes[24];
byte w_operating_capacity = bytes[17];
byte w_water_flow = bytes[18];
byte w_recirculation_enabled = bytes[33];
bool system_power = (w_system_power & 0x5) ? true : false;
byte flow_state = w_flow_state;
bool consumption_active = (w_flow_state & 0x20) ? true : false;
bool recirculation_running = (w_flow_state & 0x08) ? true : false;
float set_temp = w_set_temp/2.F;
float outlet_temp = w_outlet_temp/2.F;
float inlet_temp = w_inlet_temp/2.F;
bool display_metric = (w_system_status & 0x8) ? true : false;
bool schedule_active = (w_system_status & 0x2) ? true : false;
bool hotbutton_active = (w_system_status & 0x2) ? false : true;
float operating_capacity = 0.5F * w_operating_capacity; // 0.5 increments
float flow_lpm = w_water_flow/10.F;
bool recirculation_active = (w_recirculation_enabled & 0x2) ? true : false;
id(dc_system_power).publish_state(system_power);
id(dc_flow_state).publish_state(flow_state);
id(dc_consumption_active).publish_state(consumption_active);
id(dc_recirculation_running).publish_state(recirculation_running);
id(dc_set_temp).publish_state(set_temp);
id(dc_outlet_temp).publish_state(outlet_temp);
id(dc_inlet_temp).publish_state(inlet_temp);
id(dc_display_metric).publish_state(display_metric);
id(dc_schedule_active).publish_state(schedule_active);
id(dc_hotbutton_active).publish_state(hotbutton_active);
id(dc_operating_capacity).publish_state(operating_capacity);
id(dc_flow_lpm).publish_state(flow_lpm);
id(dc_recirculation_active).publish_state(recirculation_active);
- id: decode_gas_packet
mode: parallel
max_runs: 1
then:
- logger.log: "Navien GAS packet ^^^^"
- lambda: |-
std::vector<uint8_t>& bytes = id(gas_packet_bytes);
byte g_set_temp = bytes[14];
byte g_outlet_temp = bytes[15];
byte g_inlet_temp = bytes[16];
byte g_controller_version_lo = bytes[10];
byte g_controller_version_hi = bytes[11];
byte g_panel_version_lo = bytes[12];
byte g_panel_version_hi = bytes[13];
byte g_cumulative_gas_lo = bytes[24];
byte g_cumulative_gas_hi = bytes[25];
byte g_current_gas_lo = bytes[22];
byte g_current_gas_hi = bytes[23];
byte g_total_operating_time_lo = bytes[36];
byte g_total_operating_time_hi = bytes[37];
byte g_cumulative_domestic_usage_cnt_lo = bytes[30];
byte g_cumulative_domestic_usage_cnt_hi = bytes[31];
float set_temp = g_set_temp / 2.F;
float outlet_temp = g_outlet_temp / 2.F;
float inlet_temp = g_inlet_temp / 2.F;
char controller_version_[20]; // some insurmountable ESPHome compile error with atof(), so report it as a string
snprintf(controller_version_, sizeof(controller_version_), "%d.%d", g_controller_version_hi, g_controller_version_lo);
char panel_version_[20];
snprintf(panel_version_, sizeof(panel_version_), "%d.%d", g_panel_version_hi, g_panel_version_lo);
uint32_t raw_gas = (g_cumulative_gas_hi << 8 | g_cumulative_gas_lo);
float accumulated_gas_usage = 0.1F * raw_gas; // Using float multiplication for better precision
float current_gas_usage = g_current_gas_hi << 8 | g_current_gas_lo;
// Convert total operating time to seconds using 32-bit arithmetic
uint32_t raw_time = (g_total_operating_time_hi << 8 | g_total_operating_time_lo);
uint32_t total_operating_time = 60 * raw_time; // Safe with uint32_t
// Convert domestic usage count using 32-bit arithmetic
uint32_t raw_usage = (g_cumulative_domestic_usage_cnt_hi << 8 | g_cumulative_domestic_usage_cnt_lo);
uint32_t accumulated_domestic_usage_cnt = 10 * raw_usage; // Safe with uint32_t
id(dc_controller_version).publish_state(controller_version_);
id(dc_panel_version).publish_state(panel_version_);
id(dc_accumulated_gas_usage).publish_state(accumulated_gas_usage);
id(dc_current_gas_usage).publish_state(current_gas_usage);
id(dc_total_operating_time).publish_state(total_operating_time);
id(dc_accumulated_domestic_usage_cnt).publish_state(accumulated_domestic_usage_cnt);
- id: decode_other_packet
max_runs: 1
mode: parallel
then:
- logger.log: "Navien OTHER packet ^^^^"
WJCarpenter
