Web UI homepage update - displays basic weather info
11/04/2025 at 07:17 • 0 comments![Web Interface Web Interface]()
A picture of the web interface, with time and weather data being separated into different panels, plus a non-functional section for controlling the USB ports. Currently, only the time, date, temperature, pressure, and humidity work. ![LCD LCD]()
A picture of the prototype, with the LCD attached. The time, date, humidity, and temperature are shown.
I've made some progress with the project (albeit slowly because I'm kind of busy). Right now I've managed to get some basic time and weather info being displayed on a 240*320 LCD and a web interface. Next step is to get the alarm system working and improve the UI on the LCD. Stay tuned! -
Starting on web interface
05/18/2025 at 10:22 • 0 commentsOK, so I've done a bit of research on ways to create a web server on the ESP32, and I've decided to use the ESPAsyncWebServer library to create and manage the web server, as apparently it's supposed to be better than the WebServer.h library and it should work fine for what I need it to do. Maybe there's something better out there, I don't know. If there's issues maybe I'll go with something else, like Mongoose, which looks interesting.
Honestly I've never done anything like this before, so my head hurts every time I have to look at this stuff. And starting is probably the best way to stop that from happening.
Suggestions on what to use are welcome. Stay tuned!
Initial entry - Basic proof of concept code + test rig completed
05/14/2025 at 07:27 • 0 commentsSorry, it's been a long time since I started this project page.
It's one thing to start a project, another thing to actually follow through and finish it.
I've acquired a DS3231 and BME680 (I wanted a BME280, but since I got it for free from my local hackerspace, I don't mind the extra features), and I've wired them up with my ESP32-WROOM-32 devboard as a simple proof of concept at least two weeks ago. I've also recently finished making a simple text-based proof of concept program that allows the user to connect to WiFi, automatically update the RTC upon connection and output the time, with an NTP-only fallback in case the RTC is missing. As I don't currently have the display I need to create the actual UI for the clock, I'm planning to start working on the web server to remotely manage and control the clock. Right now I'm starting to figure out how I'm actually going to create the website.
I have some experience with HTML, but I haven't done anything really complex with it. There seem to be some interesting-looking web development frameworks, so at this point I'm not really sure what I'll use. I'll update this project log when I've decided what I'm going to be using.
Picture of the proof of concept circuit:
Test program in action:
Stay tuned!
Daniel
