LCD display have a diffusing plastic glass. I wanted to make use of one as to recycle that piece.
I got a 22" display, broken and salvage the plastic glass. The glass as a >PMMA< marking. It is acrylic. The LCD backlight acrylic has an interesting feature, one of the sides has white dots reflecting light that shines thru. If there was not dots, I would not get much light diffused from the lamp.
I made a design base on an earlier lamp I made. The frame is made of MakerBeam and Aluminum U-Channel. The U-Channel I used is very thick and I am able to use it as part of the frame.
I plan to use custom 6mm PCB LED strip to shines light at the edge of the acrylic. As i didn't find a 6mm wide LED strip with RGB LED, I designed one my self. As the frame was assembled, I used LCD backlight led upgrade kit meanwhile I did my custom one. The update kit is white LED on a 4mm wide PCB. Those even slide into a MakerBeam giving me idea for other usage once I replace them.
I made a 3D CAD of my lamp to plan how the U-Channel and the MakerBeam come together. From the model I generated blueprints to drill the 140 holes ( M2, M3 and M6 holes ). The U-Channel are attached to the MakerBeam with M3 screws and the custom PCB strip with M2 screws. The 6mm holes are to pass wire thru.
Stanislas Bertrand
bobricius
Thomas Chanon Wangtrirat
Grayson Schlichting
Is there more?
