PCB - 3D Startrek Enterprise
40 led flashing 3D space ship model
Starting from
has orders / reviews
Ships from
Animated version:
- 10x10 cm of PCB board
- Attiny85 to individual control 20 LED with charlieplexing
- 40 LED total
- sound output (not working in this version, bug on PCB)
- AAA battery in stand for power
- full 3D construction
- it can not fly :-(
Simplified version:
- without MCU, chip crisis resistant
- ideal as solder learning toy
BOM (this is my crazy configuration, you can use 0805 or 0603 LEDS):
  • MAIN BOARD
    - 1x Attiny 85
    - 4x Spring battery holder BCL82PC (KEYSTONE)
    - 4x 47R 0603
    - 1x 100n 0603
    - 1x mode switch PTS810SJG250SMTRLF (C&K)
    - speaker not working now, do not solder
  • PLASMA COILS
    - 10x 3014 blue LED on coil
    (3014 LED is very hard to solder without hot air gun, you can use 0805)
    - 2x 0802 red LED on front - this is side LED
    - 2x 0802 yellow LED on tail - this is side LED
  • DEFLECTOR
    - 6x 0603 blue led
  • MIDDLE BOARD
    - 4x 0802 red LED, 2 on tail, 2 under plate - this is side LED
    (do not mix, use same color)
  • PLATE
    - 1x clear white LED 8mm as bridge
    - 6x 3014 white LED
    - 1x 0805 pink LED, above NCC - 1701 text, soldered on side
    - 4x 0805 white LED, under bridge, soldered on side
    - 1x 4014 green LED as laser
FIRMWARE
  • Attiny85 compiled firmware (hex) and sources in FILES section
  • FUSES: lfuse:w:0xc2:m  hfuse:w:0xdf:m  efuse:w:0xfe:m
    (8Mhz, BOD off)
Assembly Instructions V1.pdf
Amazing assembly guide by John Toebes
Adobe Portable Document Format - 2.54 MB - 01/15/2023 at 19:33
Preview
enterprise-EASY-Solder.pdf
Simplified version without MCU
Adobe Portable Document Format - 589.90 kB - 04/19/2022 at 20:48
Preview
enterprise-Animated.pdf
LED position card
Adobe Portable Document Format - 655.63 kB - 12/05/2019 at 13:27
Preview
ENTERPRISE_HEX.zip
Compiled firmware enterprise.hex lfuse:w:0xc2:m -U hfuse:w:0xdf:m -U efuse:w:0xfe:m Just run enterprise_upload.bat
x-zip-compressed - 195.75 kB - 09/25/2019 at 20:59
Download
Portable Network Graphics (PNG) - 22.35 kB - 09/18/2019 at 21:37
Preview
View all 12 files
View all 5 project logs
Zef wrote 05/16/2025 at 02:15 point
Any change of releasing gerbers for people in countries that cannot order (or is way too expensive) from dirtypcb?  Would really appreciate it. Great project!
Gerben wrote 05/16/2025 at 11:55 point
The dirtypcb links seems to be for the old version. The schematic and board file for the new PCB are in the files section.
Zef wrote 05/18/2025 at 05:27 point
Yes, but I can't generate gerber files from them can I?  EDIT: Actually I've tried importing the .brd file to Kicad but I can't get it to generate gerber files that include the cutouts.  It doesn't seem to import very well and I don't understand the "mapping" Kicad asks me to do.  The automapping feature doesn't seem to grab everything it needs.  If anyone is able generate proper gerber files for this project I would love to know how to do it.
Andrea wrote 06/20/2020 at 20:06 point
Does anyone have spare pcb's left over? I don't really see the point of ordering 10 pieces for $40 including shipping. I'm willing to pay $10 + enveloppe shipping for just a single pcb.
Daniel wrote 11/13/2019 at 07:32 point
Great project! I also ordered the boards. Unfortunately, there seems to be a problem with the hex file which I have downloaded here. In the video you should see the problem: https://youtu.be/bO3Jmj0WaZk
Is there another version?
bobricius wrote 11/13/2019 at 07:54 point
Hi, sorry for troubles, I no add assembly instructions, I am very bad in writing manual.
it is look like your battery board is reversed, just solder battery base board with readable logo to you, chcek my pictures.
PS: great job, nice to see my project replication.
Daniel wrote 11/13/2019 at 08:30 point
Thank you for your reply. Now I see it. Then I have to turn that :) Thank you!
Kevin wrote 10/30/2019 at 01:38 point
Anybody have a BOM for Digi or Mouser?
pgvoorhees wrote 01/11/2020 at 03:55 point
I'm ordering this now: https://pastebin.com/VPNC49LW
wish me luck.
Kevin wrote 01/11/2020 at 20:16 point
Thanks so much. The Digi parts were all in stock!
Dustin Westaby wrote 09/14/2020 at 13:15 point
I used your list.  It turned out great~!  I ordered a pack of pink LEDs from ebay.
Eric Chapin wrote 10/20/2019 at 05:48 point
The BRD file seems to be missing outline information, which makes it impossible to generate gerber. I wanted to send the files to different PCB fab (have issues with Dirty PCB) and I wanted a few in different mask color for making them into Christmas ornament including red, yellow, green, blue, purple, and white.
bobricius wrote 10/21/2019 at 18:55 point
you can order from my dirtypcbs store and select another color
akonitzko wrote 09/24/2019 at 16:05 point
I am interesting for a easy solder version without programming MCU.
Can anyone send me a programmed ATTiny 85 for money ?
bobricius wrote 09/25/2019 at 21:50 point
I put in files compiled HEX + uploader for easy setup. I created item in my store https://www.tindie.com/products/4997/
Falk Brunner wrote 09/17/2019 at 17:21 point
Could you please provide a BOM and an assembly plan. (Yes, I could figure it out by reverese engineering, but this is not the way it's meant to be, isn't ist?) This takes 5 minutes in eagle. I already ordered from dirty PCBs! Great project, nice design!
thekat858 wrote 09/16/2019 at 02:34 point
This looked like a cool project, but as it turns out, $38 is bit too steep for me for 10 PCBs.
My original order was about $20, but I was informed by Dirty PCBs that the product was oversized.  The product price doubled and shipping quadrupled. (FYI - It will cost you $0.50 to get a PayPal refund.)
bobricius wrote 09/16/2019 at 04:23 point
sorry, I need pay bills and buy food for my kids. I get 9$ from order. Dirty pcb have very bad shop interface.
Noxmiles wrote 09/05/2019 at 16:24 point
Is there a part list anywhere? "assembly by pictures, you can use leds as you want" is a bit tricky when you only have these pictures to order the stuff.
bobricius wrote 09/05/2019 at 18:20 point
I create part list.
tbnobody wrote 09/05/2019 at 13:48 point
Do you also provide a BOM or schematic? Without that it's quite difficult to find all parts.
Daniel Zhou wrote 05/16/2019 at 05:13 point
Thanks for you reply. Can i get r gerber files or drawing than i can send to a local pcb manufacturer?I did not find a way to download from dirtypcb.com.
Marcos wrote 06/10/2019 at 23:30 point
+1!
Can't ship to my country from dirtypcbs.
Daniel Zhou wrote 05/14/2019 at 07:03 point
Is there gerber that were released?
kimtherock wrote 08/27/2019 at 17:03 point
hi there i would like to build this project is there anyway of releasing the gerbers please as i have a dispute with dirtypcbs.  thanks  kim
Anthony DiGirolamo wrote 01/10/2019 at 17:08 point
Wow! I'd definitely build one of these.
me wrote 01/06/2019 at 03:42 point
Hi, beautiful. the gerber (or pcb) files will be released?
Yann Guidon / YGDES wrote 12/22/2018 at 05:10 point
Now, why don't you make it fly ? :-P
deʃhipu wrote 12/22/2018 at 00:27 point
It's beautiful!
davedarko wrote 12/08/2018 at 11:02 point
I will keep an eye out on tindie for this beauty :)
davedarko wrote 12/22/2018 at 14:37 point
seriously :D
Vincent wrote 12/22/2018 at 23:48 point
Same here!
thelogicofpi wrote 06/14/2019 at 16:32 point
