BOM (this is my crazy configuration, you can use 0805 or 0603 LEDS):
- MAIN BOARD
- 1x Attiny 85
- 4x Spring battery holder BCL82PC (KEYSTONE)
- 4x 47R 0603
- 1x 100n 0603
- 1x mode switch PTS810SJG250SMTRLF (C&K)
- speaker not working now, do not solder - PLASMA COILS
- 10x 3014 blue LED on coil
(3014 LED is very hard to solder without hot air gun, you can use 0805)
- 2x 0802 red LED on front - this is side LED
- 2x 0802 yellow LED on tail - this is side LED - DEFLECTOR
- 6x 0603 blue led - MIDDLE BOARD
- 4x 0802 red LED, 2 on tail, 2 under plate - this is side LED
(do not mix, use same color) - PLATE
- 1x clear white LED 8mm as bridge
- 6x 3014 white LED
- 1x 0805 pink LED, above NCC - 1701 text, soldered on side
- 4x 0805 white LED, under bridge, soldered on side
- 1x 4014 green LED as laser
FIRMWARE
- Attiny85 compiled firmware (hex) and sources in FILES section
- FUSES: lfuse:w:0xc2:m hfuse:w:0xdf:m efuse:w:0xfe:m
(8Mhz, BOD off)
bobricius
Stanislas Bertrand
Michael
Sam Ettinger
Any change of releasing gerbers for people in countries that cannot order (or is way too expensive) from dirtypcb? Would really appreciate it. Great project!
