Step 1: Cutting the FPC Board:
Take a piece of FPC flexible circuit board and cut along the white line on the front of the board.
Step 2: Sanding the TYPE-C Interface:
Take a 16-pin surface-mount TYPE-C connector and sand down the four mounting pillars on both sides to make soldering easier. I used 400-grit sandpaper for sanding. Be extra careful not to damage the pins while sanding.
Step 3: Comparison Image:
The left side is before sanding, and the right side is after sanding.
Step 4: Soldering
Apply solder to the FPC board and proceed with soldering.Note: Using a soldering stencil is not mandatory. If your manual soldering skills are good, you can directly solder the TYPE-C connector, but this may require some expertise.
- First, solder the sanded TYPE-C connector.
Step 5:
- Pay special attention to the 16 pins and 4 mounting pillars to ensure proper soldering and avoid solder bridges or cold joints.
- Finally the 16 pins and 4 mounting pillars to ensure proper soldering and avoid solder bridges or cold joints.
- Finally, solder the two 5.1kΩ resistors.
After soldering, carefully check for any soldering defects to ensure the connections are secure. Then, clean the board, and the assembly is complete.
Step 6: Power Extraction Test
The image below shows the board extracting power normally and demonstrates the excellent flexibility of the FPC board. This FPC from jlcpcb . Now they also support transparnet pcb ,with the coupon only : $5.8 .
Rasmus L.
Andrew
Daniel Garcia
Bruce Land
