Submarine Wiring Connections.pdf
Adobe Portable Document Format - 311.70 kB - 07/15/2025 at 05:57
Preview
Portable Network Graphics (PNG) - 97.47 kB - 07/15/2025 at 05:57
Preview
75mm Sub Control Plate.pdf
This is the 75mm control plate, required for laser cutting. Process this in 2mm or 3mm Mild steel.
Adobe Portable Document Format - 3.90 kB - 07/10/2025 at 06:08
Preview
The finished submarine
JPEG Image - 96.16 kB - 07/07/2025 at 10:45
Preview
This a 12v Solenoid Valve, which comes from an water filter. It is sold as a spare part.
JPEG Image - 31.67 kB - 07/08/2025 at 10:13
Preview
We need 1x of this coupling. Pipe diameter 75mm
Portable Network Graphics (PNG) - 91.34 kB - 07/08/2025 at 10:11
Preview
We need two of these reducers. Small Pipe Diameter 75mm. Large Pipe Diameter 110mm. These will act as the ballast.
Portable Network Graphics (PNG) - 96.84 kB - 07/08/2025 at 10:10
Preview
Zoomed View of Connecting Silicon Pipe to Press Fit Connectors.
JPEG Image - 530.23 kB - 07/09/2025 at 07:07
Preview
Top View of the Ballast Control
JPEG Image - 601.96 kB - 07/09/2025 at 07:07
Preview
Side View of the Ballast Control
JPEG Image - 397.90 kB - 07/09/2025 at 07:07
Preview
This is a suction and pressure pump, depending on where a pipe is connected. We use two of these. One of the pumps help push the water out of the ballast, one of them pulls the water into the ballast.
JPEG Image - 108.25 kB - 07/08/2025 at 10:13
Preview
The different kind of connectors we will need.
Portable Network Graphics (PNG) - 94.24 kB - 07/08/2025 at 15:11
Preview
