Add learning mode
A project log for IR power switch for NucBox G5
Add IR power switch to a mini PC to turn on it with TV remote.
teruteru • 08/03/2025 at 06:36•0 Comments
Added code learning mode so power on code can be changed without uploading firmware.
Add push switch between IR pin and ground, and hold it down while reset, then device enters learning mode.
In this learning mode, device accepts IR signal twice. If the 2 signals are same, it is saved to eeprom and will be used as power on code.
