Project Status 3
4 hours ago • 0 commentsUpdates since 27 AUG 2025
- replaced J8 and J9 (LEFT_ENABLE and RIGHT_ENABLE) with jumpers
- changed SW1 symbol and footprint
- changed USB Micro symbol and footprint
- added ESD protection to micro USB
- replaced boot switch to boot button
- added crystal capacitor calculations
- added grounded mounting holes
- changed all 0402 to 0603 for hand-soldering
- "Do not populate" for J3, J11
- changed J11 pinout for better trace routing
- changed J2 and J4 to horizontal connectors
- finished PCB design
- changed and added numerous printed parts
- ordered and assembled board
- verified built-in LED working
- verified laser circuit working
- verified HSE crystal circuit workingIssues
- AMS1117-5.0 was initially dead; replaced
- USB micro B had two pins shorted; lifted GND pad when trying to removeChanges to v1.1
- STEP and DIRECTION Test Points pins are incorrect on A1 and A2
- BOOT0 had a 100nF capacitor to GND instead of pull-down resistor; this caused floating issues when programmingTo do:
- test pin functions on bluepill as specified:
- end stop interrupts
- UART Tx and Rx from pi 5
- YAW/PITCH motor function
- RIGHT/LEFT motor function
- dual-camera stuff with pi 5 -
Project Status 2
08/27/2025 at 22:46 • 0 comments27 AUG 2025
Since last update:
- Added 2 test points: PITCH_STEP, YAW_STEP
- Added comments about STEP pins in schematic
- Changed PITCH_END, LEFT_END, RIGHT_END, LASER, SPARE_IN0, SPARE_IN1, SPARE_OUT0, SPARE_OUT1 pins due to external interrupt needs
- Changed focus motor drive calculations due to Adafruit motors are 1/16 ratio
- Created UART transmit codes
- Tested PWM for PA8 (PITCH_STEP) and PB0 (YAW_STEP); calculated prescaler, period counter, and pulse values
- Calculated estimated max current draw of system
- Updated Bino Pi Reference Sheet, schematic
Future Plans:
Short Term:
- Get timing interrupt to work
- Create 6 sequences for focus motor stepping: 1-phase full step CW & CCW, 2-phase full step CW & CCW, half-step CW & CCW
- Test UART and transmit codes (TX from MCU to Analog Discovery 3 working; need to test RX on MCU)
- Test endstop interrupts
- Test laser output circuit using 2N3904; determine experimental current consumption
Long Term:
- Submit PCB for fabrication
- Adjust bottom assembly mounting for PCBA
- Verify operation of PCBA
- Conduct dual-camera operations with OpenCV in Python
Project Status 1
07/30/2025 at 22:16 • 0 comments30 JUL 2025
Working on Bino Pi Gimble Control PCB.
Future Plans:
- Redesign bottom assembly mounting with PCBA
- Verify operation of PCBA for all peripherals
- Enable UART communication between Pi 5 and STM32F103C8T6
scott
