Bottom_panel.stl
Standard Tesselated Geometry - 73.32 kB - 08/06/2025 at 12:08
Download
Cover.stl
Standard Tesselated Geometry - 173.03 kB - 08/06/2025 at 12:08
Download
Front_panel.stl
Standard Tesselated Geometry - 209.26 kB - 08/06/2025 at 12:08
Download
rgb_led_holder.stl
Standard Tesselated Geometry - 175.18 kB - 08/06/2025 at 12:08
Download
Back_panel.stl
Standard Tesselated Geometry - 28.40 kB - 08/06/2025 at 12:08
Download
Left_panel.stl
Standard Tesselated Geometry - 89.14 kB - 08/06/2025 at 12:08
Download
Casefoot.stl
Standard Tesselated Geometry - 51.84 kB - 08/06/2025 at 12:08
Download
Right_panel.stl
Standard Tesselated Geometry - 90.12 kB - 08/06/2025 at 12:08
Download
Mounting_clip.stl
Standard Tesselated Geometry - 1.45 kB - 08/06/2025 at 12:08
Download
PWM_analyzer.ino
This firmware is designed for the ESP32 S3 to control the project’s functionality, leveraging the Arduino platform for easy development and deployment. The code includes essential functions for reading inputs from the encoder, processing signal data, and controlling outputs accordingly. It also manages communication with any connected peripherals and ensures smooth integration with the hardware components, including the display and any additional sensors or actuators. The firmware is optimized for real-time performance, providing seamless operation and responsiveness. The code is modular and expandable, allowing for future upgrades and customization based on specific project needs.
ino - 31.10 kB - 08/06/2025 at 10:10
Download
Schematic_PWM_Analyzer_2025-08-06.pdf
This schematic represents the electronic circuit design for the project, created using EasyEDA. It includes all the necessary components and their connections to ensure proper functionality. The schematic covers the ESP32 S3 microcontroller, encoder connections, resistors, capacitors, power management, and additional peripheral components. The goal is to provide a clear and detailed representation of the electrical layout to assist in building and troubleshooting the circuit. All components are properly labeled, and connections follow standard practices to ensure stable performance and easy integration with other systems.
Adobe Portable Document Format - 65.79 kB - 08/06/2025 at 10:08
Preview
