Satellite Communications Countdown Timer
This countdown display was built for assisting in communications with SPARCS, a 6U CubeSat from ASU's Interplanetary Initiative Lab.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This countdown timer uses a Raspberry Pi 3B+ running a python script to connect to our satellite control dashboard, retrieve times for Aquisition of Signal and Loss of Signal (AOS and LOS), and display a countdown to those times down to the decisecond. It helps our satellite operators know exactly when the satellite is expected to come into range for communication, and how long they have to check its vitals before it falls out of range again.
The display uses eight MAX7219 8x8 modules, which the Raspberry Pi communicates with using SPI and the Luma LED library.
