The board is based on an 8×8 matrix of Hall sensors (A3144), multiplexed through 74HC165 shift registers and read by an Arduino Mega 2560. Each chess piece has a small magnet embedded inside, allowing the system to detect whether a square is occupied. Since the starting positions are fixed, the firmware remembers which piece is on which square.
Under the playing surface, an individually addressable WS2812B RGB LED strip provides feedback: showing whose turn it is, possible moves, and special states such as check, checkmate, or pawn promotion.
The system is powered by a Li-Ion 21700 battery with integrated BMS, charging circuitry, and step-up converters, making the chessboard fully portable.
Game modes are selected using a unique startup method: when the board is powered on, it checks the position of the kings. If no king is lifted within 10 seconds, the board defaults to Human vs Human. If the black king is lifted and placed on any free square, the AI plays as White. If the white king is lifted, the AI plays as Black.
The firmware includes full chess rules (castling, en passant, pawn promotion) and a lightweight AI.
yourchess.official
DTW Projects
Jeremy
Abel Rodriguez
