The kit includes two flexible, high-temperature, 0.75mm² silicon-insulated sets of wires designed for use with the heaters. They allow easy routing and connection due to their flexibility. The heaters themselves have double sided tape that is suitable for high temperatures.
The main board comes in ESD protective packaging, while the ribbon cable, display and the it's board need some extra protection and they come with ESD protective box.
You will have to print the case of the printer by yourself. You can find the necessary files in the link bellow. In terms of tool hex key is needed.
