Almost Done
10 hours ago • 0 commentsJust a little Photo Update.
Minor Update
06/24/2026 at 09:47 • 0 commentsMinor Update:
1 Controller done2 Controller half done (playable, but "flightstick" missing")
2 stacked ikea lack tables as base
hdmi mod for the n64
the 4 controllers are removable for transport (the case for the controllers are just ikea lack shelfs)
first test of corner fittings and plots for the table.![]()
Small Update
06/16/2026 at 13:19 • 0 commentsSome small Update:
- Changed the screens to some used 15.6 '' Notebook screens => not so heavy- rs232 for the Matrix Controller works now with some esp8266 (wemos D1) => you can switch between 3 Modes:
1. every screen shows fullscreen
2. every screen shows 1/4 of the screen (4 player split)
3. screen 1 and 2 show half (top-botton) of the screen, 3 and 4 fullscreen (2 Player horizontal split)
- one prototype controller is done
- updated design (with some Ikea furniture) to make the build easy an portable
More Updates will come when the 4 Controllers are done and i need to install a hdmi mod to my N64, because the Signal is to Blurry (N64=>AV2HDMI=>Matrix Controller(input and output 1080p)=>old Notebook screen 1366x768) => the av or s-video output from the n64 is to blurry to come up with all this scaling...
usb2n64 test
09/20/2025 at 22:15 • 0 commentsNew Parts arived:
N64 Extension Cords and 4rp2040 pro micro
I flashed the pi picos with https://github.com/pdaxrom/usb2n64-adapter and tested everything on the real thing. Works like a charm.
Next step will be the N64 AV to hdmi converter to use the Video output of the N64 with the 2x2 Matrix controller.Flow
Used githubs, links etc
09/15/2025 at 13:39 • 0 commentsUsed Githubs, Thingiverse Files and links:
Arcade Controller:
Usb2n64, for connecting the usb gamepads to the real thing:
Starfox Controller, only Handle is used with a off the shelf Joystick:
