ESP32 Bit Pirate
A Hardware Hacking Tool With Web-based CLI That Speaks Every Digital & Radio Protocol
geoGeo
ESP32 Bit Pirate is an open-source firmware that turns your device into a multi-protocol hacker's tool, inspired by the legendary Bus Pirate.
It supports sniffing, sending, scripting, and interacting with various digital protocols (I2C, UART, 1-Wire, SPI, etc.) via a serial terminal or web-based CLI. It also communicates with radio protocols like Bluetooth, Wi-Fi, Sub-GHz and RFID.
Use the ESP32 Bit Pirate Web Flasher to install the firmware in one click. See the Wiki for step-by-step guides on every mode and command. Check ESP32 Bus Pirate Scripts for a collection of scripts.
Everything about the project: ESP32 Bit Pirate Website
Getting Started
Banner of the ESP32 Bus Pirate web flasher
  • 🔧 Flash the firmware
  • 🔌 Connect via Serial or Web
  • 🧪 Use commands like:
    mode
    help
    scan
    sniff
Wiki
Banner of the ESP32 Bit Pirate Wiki page
📚 Visit the Wiki for detailed documentation on every mode and command.
Includes:
The wiki is the best place to learn how everything works.
Scripting
Banner of the ESP32 Bit Pirate Scripts page
🛠️ You can automate interactions with the ESP32 Bit Pirate using Python scripts over serial.
Examples and ready-to-use scripts are available in the repository: ESP32 Bus Pirate Scripts.
Including: Logging data in a file, eeprom and flash dump, interracting with GPIOs, LED animation...
bit_pirate_17_cardputer-adv.bin
octet-stream - 3.86 MB - 08/14/2026 at 12:23
Download
bit_pirate_17_xiao-esp32s3.bin
octet-stream - 3.63 MB - 08/14/2026 at 12:23
Download
bit_pirate_17_heltec_wifi_lora_32_V4.bin
octet-stream - 3.64 MB - 08/14/2026 at 12:23
Download
bit_pirate_17_t-embed-s3-cc1101plus.bin
octet-stream - 3.79 MB - 08/14/2026 at 12:23
Download
bit_pirate_17_m5stack-sticks3.bin
Download
View all 31 files
  • 1 × ESP32S3 Dev-Kit Works on all ESP32S3
  • v1.7
    Geo08/14/2026 at 12:24 0 comments
    Changelog
    WEBSITE
    🔹 ESP32 Bit Pirate is evolving from a standalone firmware into a broader ecosystem built around the firmware, supported hardware and browser-based tools.
    🔹 New Web Tools extend the project directly from the browser, making common debugging, programming and analysis workflows easier to access without installing dedicated software.
    https://geo-tp.github.io/ESP32-Bit-Pirate/
    LORA
    🔹 Added a new LoRa mode for SX1262 transceivers, with packet transmission, reception and RF analysis.
    `send`, `receive`, `rssi`, `scan`, `waterfall`, `cad`
    🔹 Send and receive LoRa packets, monitor RSSI and scan frequency activity.
    `record` / `load`
    🔹 Record LoRa packets to LittleFS and replay them later with their radio configuration.
    `meshtastic`
    🔹 Added a dedicated Meshtastic analysis shell to send, receive and inspect Meshtastic packets.
    `config`
    🔹 Configure SX1262 pins, frequency, bandwidth, spreading factor, coding rate, TX power, preamble, sync word and radio options.
    https://github.com/geo-tp/ESP32-Bit-Pirate/wiki/24-LORA
    USB
    `BPIO2`
    🔹 Added a BPIO2 USB adapter for GPIO, I2C and SPI control from a host computer.
    🔹 Added sequence import/export and microsecond delay support for BPIO2 workflows.
    🔹 Added a browser-based BPIO2 controller through Web Serial.
    https://geo-tp.github.io/ESP32-Bit-Pirate/web-tools/bpio2/
    `Flashrom SPI Programmer`
    🔹 Increased the transfer buffer size.
    https://geo-tp.github.io/ESP32-Bit-Pirate/web-tools/spi-flash-programmer/
    🔹 Standardized the USB product name as `ESP32 Bit Pirate` across boards.
    🔹 Updated USB PID handling to avoid stale host-side USB configuration caching.
    https://github.com/geo-tp/ESP32-Bit-Pirate/wiki/99-Adapters
    I2C
    `dump` - Thanks to @mvanhorn.
    🔹 Added a raw-read fallback for devices that do not expose a traditional register interface.
    🔹 Regular register devices still use the full register scan behavior.
    INFRARED
    🔹 Increased the raw receive buffer from 100 to 512 entries to capture longer infrared signals.
    🔹 Fixed the IR receiver lifecycle when reconfiguring pins, preventing old receive buffers from leaking.
    Thanks to @82ghost82.
    WIFI
    🔹 Wi-Fi is now properly deinitialized and reinitialized after spam/flood operations.
    NEW BOARDS
    🔹 Added support for the Heltec Vision Master T190, including its built-in SX1262 LoRa radio.
    heltec-t190_s
    🔹 Added a dedicated Heltec WiFi LoRa 32 V4  and onboard SX1262 support.
    heltec-lora-32-v4_s
    🔹 Added initial Waveshare ESP32-S3-GEEK build support. Thanks to @iodn.
    waveshare-s3-geek_s
    MISC
    🔹 Pinned the ESP32 Arduino platform version as a temporary workaround for excessive RAM usage with the latest framework.
    🔹 Various reliability, cleanup and resource-management improvements.
    LINKS
    * Use the Web Flasher: https://geo-tp.github.io/ESP32-Bit-Pirate/webflasher/
    * Collection of scripts: https://github.com/geo-tp/ESP32-Bus-Pirate-Scripts
    * Full guide: https://github.com/geo-tp/ESP32-Bit-Pirate/wiki
    * Bus Expander: https://github.com/geo-tp/ESP32-Bus-Expander
    * ESP32 Bit Pirate Dock: https://github.com/AndreiVladescu/ESP32-Bit-Pirate-Dock
    bit_pirate_dock_board
    Get the Dock on PCBWAY
  • v1.6
    Geo06/12/2026 at 22:35 0 comments
    Changelog
    PIRATE ASSISTANT
    🔹 Added the Pirate Assistant to the WebUI.
    https://github.com/geo-tp/ESP32-Bit-Pirate/wiki/99-Assistant
    TERMINAL MODE - WIFI HOTSPOT
    🔹 The device can now create its own Wi-Fi hotspot. 🔹 Connect directly to the hotspot from a phone or computer to access the Web CLI without requiring an existing Wi-Fi network.
    https://github.com/geo-tp/ESP32-Bit-Pirate/wiki/00-Terminal
    GENERAL
    wizard
       🔹 has been reworked to reduce false-positive signal type detection.
    UART
    sniff [raw] - Thanks to @fdufnews
       🔹 Passively monitor UART activity without transmitting data.
    scan and autobaud
       🔹 Reworked for more precise UART activity and baud-rate detection.
    I2C
    trace <addr> [reg] [ms]
       🔹 Continuously monitor a specific register and display its changes.
    USB
    adapters
       🔹 Added a dedicated USB adapter selection shell to transform your device into hardware USB adapters.
    Available adapters
    USB-UART Bridge
       🔹 Expose a USB CDC serial port connected to configurable UART RX/TX GPIOs.
       🔹 Expose a serprog-compatible SPI programmer for use with flashrom.
    AVRDUDE Bus Pirate SPI Programmer
        🔹 Implement the legacy Bus Pirate binary SPI protocol used by avrdude -c buspirate.
    SUMP Logic Analyzer
       🔹 Transform the device into a SUMP-compatible logic analyzer for sigrok and PulseView.
       🔹 Supports the display and configuration of up to eight GPIO channels.
    OpenOCD Bus Pirate Adapter
       🔹 Expose a Bus Pirate-compatible JTAG interface for OpenOCD.
    USB IR Toy / LIRC Adapter
      🔹 Emulate a USB IR Toy-compatible device for infrared tools such as LIRC.
    SubGHz Raw CDC CC1101 Adapter
      🔹 Expose the CC1101 through a simple USB CDC protocol for configuration, raw capture and transmission.
    JTAG
    openocd
       🔹 Directly configure and reboot the device as an OpenOCD-compatible USB adapter.
    BLUETOOTH
    mouse
       🔹 Corrected BLE HID mouse and keyboard report definitions.
    MISC
    🔹 The project has been renamed from ESP32 Bus Pirate to ESP32 Bit Pirate across the firmware
    🔹 Configured GPIOs are now automatically protected from duplicate assignments.
    🔹 Inactive WebSocket connections are now properly closed to prevent unexpected WebUI disconnections.
    🔹 Improved the smart-card PSC prompt to make PIN/security operations less confusing.
    🔹 Improved HTTP server and hotspot-mode initialization.
    🔹 Harmonized data prompt for flash and eeproms operations.
    🔹 Reworked SubGHz reception around a ring buffer to avoid losing pulses while captured data is transferred or displayed.
    🔹 Fixed CC1101 initialization on ESP32-S3 devices. Thanks to @AmorFati-coder.
    🔹 The CC1101 is now properly deinitialized after transmit operations. Thanks to @manato-tajiri.
    🔹 Various reliability, cleanup and resource-release improvements.
    LINKS
  • V1.1
    Geo09/29/2025 at 23:37 0 comments
    v1.1 Latest
    Changelog
    I2C
    • sniff 🔹 More readable data, improvements.
    DIO
    • pulldown <pin> 🔹 Active pulldown resistor on given pin
    SUBGHZ
    • load 🔹 Fixes and improvements.
    • listen 🔹 RSSI to audio mapping (using I2S configured output or internal speaker if any)
    • replay 🔹 Fixes and improvement.
    STANDALONE TERMINAL MODE (New)
    Use arrows up/down to scroll and esc to scroll down line by line. Use tab for command history.
    standalonemode_s
    MISC
  • V1.0 Changelog
    Geo09/26/2025 at 09:45 0 comments
    v1.0 Latest
    Changelog
    INFRARED
    WIFI
    SUBGHZ
    RF24 (New mode)
    • scan
      🔹 Search best active channel.
    • sniff
      🔹 Sniff raw frames.
    • sweep
      🔹 Analyze channels activity.
    • jam
      🔹 Jam selected channels group.
    • setchannel
      🔹 Set operating channel.
    • config
      🔹 Configure NRF24 settings.
    LittleFS (Storage / Import & Export)
    New Device Supported
    • M5Cardputer ADV
    Misc / Notes
View all 4 project logs
  • 1
    Flash the firmware
    Banner of the ESP32 Bit Pirate web flasher
    1. 🔧 Flash the firmware
    2. 🔌 Connect via Serial or Web
    3. 🧪 Use commands like:
      mode
      help
      scan
      sniff
  • 2
    Documentation
    Includes:
  • 3
    Scripting
    🛠️ Automate interactions with the ESP32 Bit Pirate using Python scripts over serial.
    Examples and ready-to-use scripts are available in the repository: ESP32 Bit Pirate Scripts.
View all 5 instructions
mbt28 wrote 10/02/2025 at 09:55 point
Hello,
Thank you for the nice project. I tried it with my esp32-s3 for I2C debugging however it is a bit difficult to understand output especially if there is so much bus communication. I wish it is able to output slave address in hex and indicate read/write condition and share the data in hex until the message completes.
Geo wrote 10/02/2025 at 13:13 point
If you're talking about the I2C sniffer, it has been reworked in version 1.1 to display the data in a more readable way.
