BREP.io A browser based parametric modeler.
Sketches with constraints and a feature history. What more could you want.
A brand new BREP kernel from scratch. Not using OpenCASCADE.
A feature-based modeling playground experimenting with BREP-style workflows on top of triangle meshes. It combines robust manifold CSG with a simple face/edge representation, a history pipeline, and Three.js visualization.
Current features:
Primitive Cube, Primitive Cylinder, Primitive Cone, Primitive Sphere, Primitive Torus, Primitive Pyramid, Plane, Datum, Sketch, Extrude, Sweep, Loft, Revolve, Mirror, Boolean, Fillet, Chamfer, Remesh, Import 3D Model (STL/3MF), Image to Face (image trace), Transform (move/rotate/scale), Pattern Linear, Pattern Radial
BREP
Source repo https://github.com/mmiscool/BREP
A feature-based modeling playground experimenting with BREP-style workflows on top of triangle meshes. It combines robust manifold CSG (via the Manifold library) with a simple face and edge representation, a history pipeline, and Three.js visualization. Import meshes (STL), repair and group them into faces, then perform boolean operations, fillets, chamfers, sweeps, lofts, and more.
This project is actively evolving; expect rough edges while APIs settle. Modeling Mode Sketch Mode PMI Mode Image to Face 2D Trace Image to Face 3D Result
Documentation Map
Mode Guides
Feature Guides
License
See LICENSE.md. This project uses a dual-licensing strategy managed by Autodrop3d LLC.
Contributing
See CONTRIBUTING.md for guidelines on submitting pull requests, reporting issues, and participating in discussions.
View all 21 project logs
