Wire harness auto routing
03/15/2026 at 08:39 • 0 commentsWorking on a bit of functionality to make wire harnesses for getting wire lengths and laying out wire harness bundles
2D sheets for printed instructions and stuff.
03/15/2026 at 05:08 • 0 commentsJust added a power point/google slides style 2D sheets editor that lets you insert PMI views and put other information on to a page. It supports a bunch of different sheet sizes and outputs PDF documents.
Fun fact. When you save a model a PDF gets generated and stuffed in to the 3MF file. 3MF files are basically a zip file so extra stuff can go in there like your build instructions or inspection documents.
Draggable grips for quick editing of dimensions.
03/01/2026 at 22:27 • 0 commentsDraggable grips.
Reworking all the sheet metal code to a mid plane approach
02/15/2026 at 08:48 • 0 commentsWorking on making more complex sheet metal parts and getting more accurate flat patterns with kfactor accounted for during unfold.
Faceted step file export
01/28/2026 at 01:32 • 0 commentsJust implemented my first cut at faceted step file export from BREP.io
Undo/redo functionality ctrl+z
01/25/2026 at 00:00 • 0 commentsVery happy about this one. You can now undo.
Face, Edge and Solid color assignment
12/24/2025 at 08:06 • 0 commentsWanted to put together a fun little model for Christmas in the modeling software.
In order to do that I needed to add face color functionality to get the right effect. Behold the face color functionality is now working.
Might have to model some presents under the tree next but am happy with this for now. Pushing the changes now and it should be live at https://BREP.io![It's a tree It's a tree]()
It's a tree -
Added ability to interrogate individual triangles and relationships with neibors
12/23/2025 at 04:13 • 0 commentsWhen building a new BREP kernel some times things get sticky and you need to do in depth interrogation of the triangulated result. I have come to the conclusion that it is not just about being able to write good software. You need to make it so that you can inspect and interrogate things to figure out the bugs and problems and not just at a surface level but all the nitty gritty details.
The triangle inspector lets me interrogate individual triangles and the topology around them.![]()
Improved holes and hole callouts
12/14/2025 at 03:10 • 0 commentsAdded more options for the hole callout to provide a hole quantity from the feature and before/after text.
Working on making modeled threads. Hope I did not screw any thing up :-P
12/09/2025 at 03:03 • 1 commentWorking on making modeled screw threads.
mmiscool
