Summary
A 16×2 LCD controller built entirely from multiplexers and logic gates — no microcontroller, no firmware. This project demonstrates how 8 multiplexers (4:1) can be configured as a ROM to execute a complete LCD initialization sequence and later allow user input in ASCII through simple pushbuttons. It is a working proof that digital logic alone can replicate the core functions of a microcontroller.
Inspiration
Every tutorial on LCDs starts with an Arduino. But what if you removed it — completely?
That question led me to an unusual challenge: build a self-contained LCD controller without using any programmable device. The idea evolved through several experimental phases — from random number generators and asynchronous counters to the creation of a custom instruction memory made entirely of multiplexers.
The result: a logic-based LCD driver that initializes the display automatically and then allows users to type any ASCII character through a hardware keyboard.
How It Works
1. System Overview
The project is divided into six functional blocks:
| Subsystem | Function |
| Clock Generator (NE555) | Produces pulses for synchronization. |
| Instruction Memory (8×MUX 4:1) | Acts as ROM to send 4 preprogrammed LCD instructions. |
| Control Unit (Counters + Logic) | Sequences the instructions and switches to manual mode. |
| Keyboard Interface (Pushbuttons + Logic) | Allows user to input ASCII data manually. |
| Display Driver (Logic OR + LCD) | Routes either automatic or user data to the LCD. |
| Power & Brightness Control (MOSFETs) | Regulates contrast and backlight with pushbuttons. |
2. Instruction Memory (Abusing Multiplexers)
At the heart of the project lies a memory made from 8 multiplexers 4:1 (74LS153).
Each multiplexer stores one bit of a 4-word ROM. Two control lines (S<sub>0</sub>, S<sub>1</sub>)
select which instruction is active:
| S1 | S0 | D7 D6 D5 D4 D3 D2 D1 D0 | Instruction |
| 0 | 0 | 0 0 1 1 0 0 0 0 | Configure 8-bit mode |
| 0 | 1 | 0 0 1 1 1 0 0 0 | Enable 2 lines |
| 1 | 0 | 0 0 0 0 1 1 1 1 | Show cursor |
| 1 | 1 | 0 0 0 0 0 0 0 1 | Clear display |
Each combination of (S<sub>1</sub>, S<sub>0</sub>) triggers a unique 8-bit word that the LCD interprets as a valid command.
This structure transforms the MUXes into a hardware ROM.
3. Control Logic (Sequencing the Memory)
The sequence through the four instructions is handled by a 4-bit binary counter (74LS193).
The counter cycles through 00 → 01 → 10 → 11, feeding the selection inputs of all MUXes simultaneously.
When the counter finishes the sequence, a control signal EN switches the system into user mode.
Truth Table for Memory Sequencing
| Time (t) | S1 | S0 | EN (Active) | Description |
| 0 | 0 | 0 | 1 | Send first instruction |
| 1 | 0 | 1 | 1 | Send second instruction |
| 2 | 1 | 0 | 1 | Send third instruction |
| 3 | 1 | 1 | 1 | Send fourth instruction |
| 4 | – | – | 0 | Stop automatic mode |
Once EN = 0, the control is transferred to the keyboard circuit.
4. Keyboard Interface (ASCII Entry)
The keyboard consists of pushbuttons representing binary bits (D0–D7) and an ENTER key. The user sets the desired 8-bit ASCII code manually and presses ENTER to send it to the display.
Example: To send the character ‘8’ (ASCII 56, binary 0111000):
| D7 | D6 | D5 | D4 | D3 | D2 | D1 | D0 |
| 0 | 1 | 1 | 1 | 0 | 0 | 0 | 0 |
Pressing ENTER triggers a short pulse equivalent to the LCD “Enable” command.
5. Dual Data Input
A logic OR gate merges signals from both the automatic memory and the user keyboard. During initialization, only the ROM is active. Once setup is complete, the MUX memory is disabled, allowing user inputs to flow freely into the LCD pins.
This transition mimics the firmware “setup() → loop()” structure found in microcontrollers — but achieved with nothing but hardware.
6. Power, Brightness, and Contrast Control
To make the system self-contained, a custom voltage regulator and brightness/contrast controller were...
Jesus Angel Martinez Mendoza
Brandon Reinhart
zpekic
"It is a working proof that digital logic alone can replicate the core functions of a microcontroller"
This is why microcontroller have been made, to emulate digital logic. They are simpler and cheaper, that's it. Digital logic is faster, so when speed isn't an issue...
