In one of my less attentive moments I connected the display to the wrong voltage and fried every semiconductor on the board. The board was then put in a box and forgotten. I found it again not long ago and the memories came flooding back.
Step 1. Identify all the cooked components, figure out what the other un-populated ones are and order replacements.
Step 2. Replace all components and install the un-populated ones then write some software to test the dot matrix display. Make a ISP cable to allow programming and serial communcations.
Step 3. Write software to display time from the RTC, Temperature from the DS18B20.
Phil
Alex
M.daSilva
Steve Anderson
Arduino Enigma
