Planned Specs:
- Compute
- Raspberry Pi 4 Model B
- Video
- Pi Cam 3 NoIR (Standard Angle)
- Targeting 720p60fps w/ H.264 encoding
- Illumination
- Custom 8-LED 850 nm IR board (120 degree spread, MOSFET-controlled PWM)
- Drive Platform
- Four-wheeled, low profile chassis
- Using 2x brushless DC motors w/ planetary gearboxes and drivers built in
- Power
- Custom 2P4S Li-ion pack (estimated 9-10 Ah, 16.8 V max) with a BMS for protection.
- Charging will come from an external CC/CV charging brick
- Electronics
- Custom power distribution board (PDB) for the Pi, motors, IR LED board, etc.
- TVS, reverse-polarity protection, and inrush limiting planned
- Networking
- Base station with a directional antenna (Yagi / panel) to extend range
- Rover will have a USB Wi-Fi adapter with an external waterproof omnidirectional antenna, estimating 1-2 dB gain
- Enclosure
- 3D printed chassis with a custom-machined aluminum baseplate for stability
- Low center of gravity; laptop-ish footprint
- Weather-resistant seals
- Active-cooling with a Noctua A4x20-PWM (12 V)
Current Status (Early WIP)
As of 11/14/2025:
- First revision of the IR LED board is designed, fabricated, and tested.
- Seems to work great, even at only 9 V supplied (rated for 12 V)
- Basic power and control concepts for the PDB are worked out on paper.
- High-level system architecture is defined
- The rover's chassis is almost done - I just need to finish up the power distribution board and define the exact buck converters I'm using to finish the design
Right now this is very much a “slow build” side project. I’m documenting as I go so others can follow along (or yell at me when I do something dumb).
Eryk Ross
TM
Teemu Hakala
Colin Catlin
