If you’re using a smart home system, chances are you already have several Zigbee devices around. While there are some nice commercial options, the vast majority of Zigbee sensors are tightly closed designs with proprietary firmware and rely on disposable lithium coin cells. I wanted to take a different path with this project: a fully open-source Zigbee sensor that runs on rechargeable NiMH cells - without sacrificing battery life or functionality.
This project was a classic case of “It can’t be that difficult”. While developing the hardware and optimizing it for low power was familiar territory, the software side turned out to be extremely challenging.
Max.K
Kris Winer
Max Carr
