2. Python Installation
APT Installation:
sudo apt install python3 python3-pip python3-venv
Since UnionTech OS (UOS) APT installation only supports up to Python 3.7, which does not meet the requirements. Therefore, use pyenv to install Python.
# 1. Install pyenv
curl https://pyenv.run | bash
# 2. Reconfigure shell (choose according to your shell)
echo 'export PYENV_ROOT="$HOME/.pyenv"' >> ~/.bashrc
echo 'command -v pyenv >/dev/null || export PATH="$PYENV_ROOT/bin:$PATH"' >> ~/.bashrc
echo 'eval "$(pyenv init -)"' >> ~/.bashrc
source ~/.bashrc
# 3. Install dependencies and Python 3.12.0
sudo apt install -y make build-essential libssl-dev zlib1g-dev libbz2-dev libreadline-dev libsqlite3-dev wget curl llvm libncursesw5-dev xz-utils tk-dev libxml2-dev libxmlsec1-dev libffi-dev liblzma-dev
pyenv install 3.12.0
pyenv global 3.12.0
3. Software Suite Download
Mainly includes CMake, ninja, etc. If these are already installed on your system, you can skip this step.
mkdir /opt/rtk-toolchain
cd /opt/rtk-toolchain
tar -xzf prebuilts-linux-1.0.3.tar.gz
You can also use the Aliyun address:
wget https://rs-wn.oss-cn-shanghai.aliyuncs.com/prebuilts-linux-1.0.3.tar.gz
The cross-compilation toolchain will also be downloaded to this path later. You can modify the permissions to avoid download failures:
chmod 777 /opt/rtk-toolchain
4. Install Dependency Libraries
sudo apt install libssl-dev libncurses5
5. Configure Environment
Enter the SDK root directory and run the ameba.sh script to automatically configure environment variables:
source ameba.sh
6. Install Toolchain
The toolchain is automatically installed to the default path /opt/rtk-toolchain during the first project compilation:
cd amebadplus_gcc_project
build.py
The toolchain package is hosted on GitHub by default, and the system will attempt to download it from GitHub during the first compilation. If you have difficulty accessing GitHub, you can use the Aliyun URL:
build.py -D USE_ALIYUN_URL=True
III. LED Blinking Test
Every time you enter the development environment, you must first run: source ameba.sh
Create a new led_test directory:
1、led.c
#include "ameba_soc.h"
#include "gpio_ext.h"
#include "os_wrapper.h"
#include <stdio.h>
void raw_gpio_demo(void)
/* Enable GPIO function and clock */
// RCC_PeriphClockCmd(APBPeriph_GPIO, APBPeriph_GPIO_CLOCK, ENABLE);
printf("example_raw_gpio_light_weight\n");
GPIO_InitTypeDef GPIO_InitStruct_LED;
// init LED control pin
GPIO_InitStruct_LED.GPIO_Pin = GPIO_LED_PIN1;
GPIO_InitStruct_LED.GPIO_Mode = GPIO_Mode_OUT;
GPIO_Init(&GPIO_InitStruct_LED);
GPIO_InitStruct_LED.GPIO_Pin = GPIO_LED_PIN2;
GPIO_InitStruct_LED.GPIO_Pin = GPIO_LED_PIN3;
GPIO_InitStruct_LED.GPIO_Pin = GPIO_LED_PIN4;
GPIO_InitStruct_LED.GPIO_Pin = GPIO_LED_PIN5;
while (1) {
GPIO_WriteBit(GPIO_LED_PIN1, 1);
GPIO_WriteBit(GPIO_LED_PIN5, 0);
rtos_time_delay_ms(1000);
GPIO_WriteBit(GPIO_LED_PIN1, 0);
GPIO_WriteBit(GPIO_LED_PIN2, 1);
GPIO_WriteBit(GPIO_LED_PIN2, 0);
GPIO_WriteBit(GPIO_LED_PIN3, 1);
GPIO_WriteBit(GPIO_LED_PIN3, 0);
GPIO_WriteBit(GPIO_LED_PIN4, 1);
GPIO_WriteBit(GPIO_LED_PIN4, 0);
GPIO_WriteBit(GPIO_LED_PIN5, 1);
int example_raw_gpio_light_weight(void)
if (RTK_SUCCESS != rtos_task_create(NULL, "RAW_GPIO_DEMO_TASK", (rtos_task_t)raw_gpio_demo, (void *)NULL, (128 * 16),
(1))) {
printf("Create RAW_GPIO_DEMO_TASK Err!!!\n");
// rtos_sched_start();
return 0;
3、gpio_ext.h
ifndef...Read more »
Ai-Thinker
jlbrian7
silver2row
Open Technology
