Still Alive
07/20/2017 at 23:55 • 0 commentsNo progress to report, I've been stuck doing less fun things. Hoping to wrap those up this week and resume here.
Also failing to get proper datasheets for some HDMI chips...
EEPROM Woes
06/20/2017 at 10:44 • 0 commentsTrying to confirm the operation of my EEPROMs (module identification), not much luck yet.
Soldered a jumper on one board to enable writing, and it seemingly accepts write commands but refuses to reply to a read request. Except it worked once. No idea why.
On the positive side, the I/O expanders work OK, I've wired a couple of pins together to confirm that (these are part of the same chip as the EEPROM, PCA9500)
ARC Module Construction Underway
06/01/2017 at 11:08 • 0 commentsI've got most of the bits on the ARC module, still waiting for an HDMI breakout to arrive (the damn plug is too hard to hand solder). In the interim, I can maybe rig up an SPDIF signal into the CS8416. More easily, I can confirm the bus switches are doing the right thing under control from the I2C I/O expander...
As Seen on HaD.com
05/30/2017 at 23:04 • 0 commentsThanks to @Jenny List for the write-up on the blog, and hello to all the new visitors here.
I will have some progress to report later this week - most of the parts are in for the ARC module. I am a bit worried that it won't work, because I don't understand the HDMI spec enough (I'm not willing to spend $5k to buy a copy). But I've got a cheap commercial ARC audio extractor to sacrifice/copy if needed, so I'll get that damn ARC data somehow.
I've also got an STM32 dev board to start doing some DSP on.
Having second thoughts about the whole backplane concept, it's going to be hard to make power amp modules work (big heatsinks). I may later change to a "hub" board with lots of plugs and some kind of switching logic.
Proof of Concept
05/09/2017 at 10:40 • 0 commentsSome good progress over the last few days. PCBs arrived, and I've assembled them - cut down a bit, I left out the bus switches for two reasons:
1. they aren't needed with only one input & one output.
2. I didn't have them.
So the first modules are essentially a weird looking Raspberry Pi add-on. One mistake I did make - no +5V. My backplane spec didn't include 5V because most parts I'm looking at using are quite happy at 3.3V. But maybe that was a mistake. Anyway, easily fixed for now with a piece of wire, and music now comes out of my DAC!
Next: I2C comms from the Pi to the IO Expander / EEPROM chip that will eventually serve as module ID & control.
ARC module layout
04/23/2017 at 06:24 • 0 commentsFirst draft of the HDMI ARC module PCB layout is done. All parts are on the top side, but I did have to use one wire jumper (for the "module enable" signal, very low speed so no problem). It's up on github.
I realised I could make the ARC chip (Explore EP91H0) function as either transmit or receive by adding a couple of resistors, so I did that. Might come in handy for testing (rather than risking damage to my far-too-expense TV, the only device I have that currently supports ARC).
I'm using the good old CS8416 for SPDIF to I2S conversion, because I still have one in my parts drawer from my last DAC project.
The Raspberry Pi adapter boards and backplane are apparently in transit. So, if I'm lucky they'll be here in a couple of weeks...
Next move: finish the layout of the ARC module (cuts & silkscreen). Might throw in a few guard traces around the high speed clocks if I remember to...
Starting the HDMI (ARC) input module
04/11/2017 at 11:32 • 2 commentsI'm using the Explore EP91H0 chip, because it's the simplest way I could find to add HDMI ARC (that's all the chip does, no video stuff).
What's ARC? "Audio Return Channel". When you plug your amplifier to your TV with an HDMI cable, the TV is able to send audio *back* to the amplifier, despite the TV's HDMI socket being an input (in HDMI parlance the TV is a "sink", and the amplifier is supposedly a "source").
I've also made the schematics a bit modular, using a common sheet for stuff that I expect to be used on most modules (in future I will refine this with further sub-sheets for mandatory / optional bits).
PCB Prototype Unit 0 - Design Files
04/10/2017 at 10:59 • 0 commentsPCB designs are now up on github, and manufacture is underway, hope to get them in a couple of weeks time.
Module
Backplane
v0 PCB Production Underway
04/06/2017 at 22:07 • 0 commentsAfter a minor glitch (forgot to export the soldermask layers), the first PCBs are now being made at @Seeed Studio.
The backplane has four PCIe 1x slots, plus debug headers.
The modules are just adapters from Raspberry Pi header to my draft PCIe 1x specification. During the process of designing the PCBs I found a few signals were pretty hard to route (I'm only using 2 layers to keep the costs down), so I think I'll re-map some pins and go to a bigger connector for the next version.
PCB designs are not updated in Github yet, I'll do that this weekend.
Starting on a test PCB
03/26/2017 at 06:08 • 0 commentsToday I worked on a PCB for proof-of-concept, essentially it will be an adapter to a Raspberry Pi header.
One module will have a Raspberry Pi, one module will have a Pi DAC module.
Once this is working, I will be able to use it to check other custom modules.
So far I have discovered one problem, that using a PCIe x1 connector probably isn't going to allow me to use more than one signal source. Pretty much all the pins are used up with 8 channels of audio, all using the same clocks. I suspect it will be impractical to sync multiple sources with the same clock (although I will look into it), so I will probably have to go to a bigger connector to allow multiple sets of 8 audio channels. Maybe I'll go for a few sets of stereo and a couple of 8 channel sets (or is stereo falling out of favour?)
Schematics are on github, unfinished, not laid-out yet.
Next: Finish schematic, layout, send for manufacture.
Andrew Bolin
