How it Works
A project log for High Dynamic Range Precision Current Supply
An open source isolated precision constant current supply from 10nA to 400mA, particularly helpful for calibrating MetaShunt power profiler
jake-wachlinJake Wachlin 12/19/2025 at 22:420 Comments
This project is fairly straightforward. The constant current supply circuit is based off of the Analog Devices AN-1530 application note for a low cost, precision constant current supply. The AD8276 Difference Amplifier and the AD8603 Op Amp are used in the current supply circuit. However, to achieve a high dynamic range, 8 different MOSFET controlled shunt resistors are used for setting the current, and the reference voltage is provided either by a fixed high 0.2% accuracy precision voltage reference or by a precision DAC (TI DAC80501). With this design then, there are two operational modes:
  1. High precision, constant reference voltage mode
  2. Precision, adjustable reference voltage mode
The MOSFETs and DAC are controlled by an onboard STM32L4 microcontroller, with USB and power isolated so that this device can get power from and communicate with a computer over a USB-C cable, while remaining electrically isolated.
