High Dynamic Range Precision Current Supply
An open source isolated precision constant current supply from 10nA to 400mA, particularly helpful for calibrating MetaShunt power profiler
0 followers
This project provides a USB-controlled, high dynamic range, precision current supply. It was designed as a calibration tool for MetaShunt V2, but can be used anywhere high accuracy, isolation, and high dynamic range is needed.
It is open source hardware, firmware, and interface.
Note: The fabrication costs of the first 2 prototype units were provided by JLCPCB as part of the OSHWLab Stars promotion. Thanks to them for the support!
Link to OSHWLabs project
Logs:
  • Testing of Constant Reference Voltage Mode
    Jake Wachlin5 hours ago 0 comments
    To evaluate the performance of this device, I started with connecting it up to a MetaShunt V2, without prior calibration of anything except the highest 2 current shunts of MetaShunt V2.
    The table below compares the expected current (from the design), compared to measurements from MetaShunt V2. The images below also show these results. Overall, the expected and measured current matches very well, all within 1% or better. Future testing will show the reliability of the current supply as a reference truth.
    Expected CurrentMeasured with MetaShunt V2% Error
    300nA302nA-0.66%
    3.30uA3.30uA0%
    30.3uA30.3uA0%
    300uA300uA0%
    3.00mA3.00mA0%
    30.0mA29.7mA1.0%
    234mA233mA0.4%
    389mA393mA-1.0%
  • How it Works
    This project is fairly straightforward. The constant current supply circuit is based off of the Analog Devices AN-1530 application note for a low cost, precision constant current supply. The AD8276 Difference Amplifier and the AD8603 Op Amp are used in the current supply circuit. However, to achieve a high dynamic range, 8 different MOSFET controlled shunt resistors are used for setting the current, and the reference voltage is provided either by a fixed high 0.2% accuracy precision voltage reference or by a precision DAC (TI DAC80501). With this design then, there are two operational modes:
    1. High precision, constant reference voltage mode
    2. Precision, adjustable reference voltage mode
    The MOSFETs and DAC are controlled by an onboard STM32L4 microcontroller, with USB and power isolated so that this device can get power from and communicate with a computer over a USB-C cable, while remaining electrically isolated.
View all 2 project logs
