Reflow.Card
A 2 PCB USB-C PD powered reflow hotplate in the form factor of a business for on the go reflow soldering
Public Chat
Reflow hotplate for soldering pcbs that uses USB-PD to deliver 100W to the heater board. This design uses two different PCBs: a heater control PCB and a heater PCB. This allows the heater boards to be consumable and swapped out if they become damaged without needing to replace the entire control PCB. This project was designed for the Hackaday business card 2024 challenge. Because there is no height limit for the challenge this design stacks both PCBs on top of each other with standoffs to be compliant.
Powered by an esp32-c3 Wroom-02 a web portal will publish the live temperature readings and allow users to upload new reflow curves. On the physical PCB there will be 2 buttons for interfacing and an mini 0.91" OLED display to know the live temperature and control.
I would like to give a huge shoutout to @Aylo6061 and his PCBHotplate Project that was the baseline for a ton of this project https://github.com/Aylo6061/PCBHotplate
This is my first exploration into high power USB-PD negotiation as well as MOSFET and gate control IC's. A ton of the time I spent on this project was understanding the fundamentals of how MOSFETs and BJTs work (even though I didn't include a BJT).
Unfortunately I didn't order the PCBs in enough time to test them and upload actual project and working tests for the Business Card Challenge, but that's just life and learning time and project management. I spent a long time trying to get a panel of both the control and heater cards from KiCAD through KiKit and hit a ton of limitations with both KiCAD and KiKit but I managed to hack it all together in the end.
I hope my creativity and usage of the infinite height set by the challenge comes across and can be appreciated.
Project files can be found on the Github page
  • 1 × ESP32-C3 Wroom 02 WiFi Bluetooth MCU for programming and control
  • 1 × COS4424 MOSFET Gate Driver for switching power to the heater PCB
  • 1 × IP2721 USB-C PD Controller for negotiating 20v 5A to to PCB
  • 1 × TPS5430DDAR Buck Converter IC for stepping down 20V to 3.3V for the MCU
  • 1 × FH3055GS 30V Single Channel MOSFET For controlling both the USB-C PD and the Heater board power
  • Reflow.Card Dev Log 6 6.30.24
    Gangwa Labs • 06/30/2024 at 19:16 • 0 comments
    After Uploading all the dev logs and Reflecting back on the progress on this project I have some thoughts about the entire process and how I've approached design and more importantly documentation.
    1. Documentation: I really wish I was documenting this project live more often instead of just uploading straight from my own notes. A better method could've been still taking my Dev Logs in my notes because I believe it's very important to write down what I'm learning and have something to look back on but more importantly after I'm done working condensing what I've learned into a more understandable and logical dev summary would be nice to look back on.
    2. Design process: I wish that I maintained a better Github for this project as it would be nice to look back on the progress that I've made and understand the design changes over time instead of just massive uploads at a time.
    Issues! I realized as I was creating the Instructions for the project that I messed up big time! In order to power the Control MCU to the proper 3.3v it needs a 20v source as I've configured it with a 20v Buck Converter. HOWEVER! In order to program it through the USB-C port it needs to come from a computer which is not going to output the 20v power. The next iteration of this design should account for that discrepancy and should integrate a switch and an LDO to direct the power through the LDO if it's getting power through a computer and is being programmed and then if it's getting power from a 20v power source it should direct power through the buck converter. It will be interesting to see how I manage that problem.
  • Reflow.Card Dev Log 5 6.21.24
    Gangwa Labs • 06/30/2024 at 19:09 • 0 comments
    This Dev Log is pulled straight from my notes
    Goals
    - [x] complete Schematic ✅ 2024-06-24
    - [x] Add all JLCPCB part numbers to components ✅ 2024-06-24
    Notes
    - found new buck converter to step down 20v pd signal to power esp32
    - Found inductor for buck converter (C2827354)
    - Found Diode for buck converter SS54 (C22452)
    - Recycled MOSFET from PD switch for Load switch for Heater
  • Reflow.Card Dev Log 4 6.2.24
    Gangwa Labs • 06/30/2024 at 19:08 • 0 comments
    This Dev log is pulled straight from my notes while working on the project
    Goals
    - understand how to read an NPN transistor datasheet
    Reading NPN Transistor Data sheets
    - VCE(sat): when the transistor is in saturation mode and is acting as a switch there is a measured drop in voltage from collector to emitter which is rated as VCE(sat)
    - NPN transistors are current driven devices so the primary information and concern is current related
    - Ic = Ib x hFE
    - Icex = collector current cutoff: leakage current through the collector to emitter when the device is off
    - hFE(includes leakeage) = hfe(small signal current gain)
    - hFE(Current gain) varies with Ic(collector current)
    - Vbe(on) = Base-Emitter on voltage: Voltage at which current begins to flow and the collector starts to draw current
    - Saturation mode: using the transistor as a switch
    - minimum voltage between the collector and the emitter is called Collector-Emitter Saturation voltage (Vce(sat)) often 0.2v to 0.3v
    - Ic at maximum: the transistor can not put anymore current through it
    - Vce at minimum: the voltage drop between collector and emitter is at a minimum
    - The current at the collector is not responding to a change in the base current
    - Power dissipation
    - Pd = Ir x Vr
    - power dissipated across a resistor is equal to the current through the resistor times the voltage across the resistor
    - Pd(total) = Pd(C) + Pd(B)
    - there is power being dissipated through both the base and the collector in a BJT
    - Pd(actual) < 0.5 x Pd(datasheet)
    - actual power dissipation must be half the rated value for safety rating
    - Ic = Max Collector Current: maximum current that you should have running through the device
    - Ic(actual) < (2/3) x Ic(datasheet)
    - actual current should be 2/3 or less of rated value for safety rating
    - Maximum Voltage rating for safety ratings
    - V(actual) < (2/3) x V(datasheet)
    - Past the saturation region is the active region where any increase in Ib doesn't increase Ic
    - In the active region the Ic stays the same over a long Vce range
    - IE. Past a certain voltage (Vce(sat)) the Transistor doesn't care what voltage is across Vce as the Ic stays the same for that Ib
    - General rule of them is that base current should be 1/10 the collector current
    Updated Design
    - Using A gate driver instead of a NPN for the MOSFET and using a dual Channel MOSFET IC
    - PD chip that can manage up to 20V 5A
  • Reflow.Card Dev Log 3 6.1.24
    Gangwa Labs • 06/30/2024 at 19:07 • 0 comments
    Goals
    - understand how NPN and MOSFET fit together to create a cheap control signal for the higher power PCB hotplate
    - Understand how the example Hotplate schematic works
    Simplified Schematic
    - NPN Transistor is acting as an inverting Switch ie. LOW from the PWM is 100% power
    - When the NPN Transistor is turned on the Gate of the MOSFET is brought to ground via the collector-emitter path and this turns off the MOSFET
    - When the transistor is off the voltage at the gate is higher than the Source(GND) and the current is free to flow through the resistive heater and from Source to Drain completing the circuit
    Sourcing Components
    MOSFET
    - 20V VGS with more than 3A of Drain continuous Current
    BJT
    - Collector to emitter voltage of 20V
    - Collector Current able to withstand more than 3A for safety rating
    - Base voltage at 3.3v micro-controller level and able to be controlled with 20mA or less of current
    Reading BJT Datasheets
  • Reflow.Card Dev Log 2 5.30.24
    Gangwa Labs • 06/30/2024 at 19:05 • 0 comments
    Goals
    - Understand the difference between N and P channel MOSFETs
    - Understand NPN transistors
    - finalize components needed in the circuit
    N channel vs P Channel Mosfet
    - N-Channel MOSFET is triggered by applying a **Positive** voltage to the gate relative to the source
    - Used when switching load side
    - P-Channel MOSFET is triggered by applying a **Negative** voltage to the gate relative to the source
    - Used when switching ground side
    NPN Transistor
    - type of BJT (Bipolar Junction Transistor)
    - commonly used for amplification or switching
    - Pins
    - Collector
    - Positive end of the transistor
    - Connected to the high voltage potential or positive supply
    - when transistor is turned on current flows from collector to emitter
    - Usually connected to the load
    - Base
    - control terminal of the transistor
    - current flowing into the base controls the current flow from collector to emitter
    - Relationship between base and collector current is determined by the transistor gain (hFE)
    - Emitter
    - Negative terminal of the transistor
    - connected to negative side or ground
    - current flows from collector to emitter when transistor is turned on
    - When enough positive voltage is applied to the base current flows from collector to emitter the amount of current that flows is proportional to the amount of current flowing into the base and is tied to the transistor gain.
    - Collector-Emitter junction is normally **Reverse-biased** meaning that the collector voltage is higher than the emitter voltage. This acts as an open switch preventing current from flowing from collector to emitter
    Datasheet Values to Look for
    - Collector-Emitter Voltage (VCEO): maximum voltage that can be applied between collector and emitter when the base is open
    - Collector-Base Voltage (VCBO): Maximum voltage that can be applied between the collector and the base when the emitter is open
    - Emitter-Base Voltage (VEBO): maximum voltage that can be applied between the emitter and the base when the collector is open
    - Collector Current (IC): Maximum continuous Current that can flow through the transistor from collector to emitter
    - Leakage Current (ICEO): Current that flows from Collector to emitter when the transistor is off
    - Power Dissipation (PD): Max power the transistor can dissipate without damage
    - Current Gain (hFE): ratio of collector current to base current
    - How much can the transistor amplify current going into the base pin
    - Transition Frequency (fT): Frequency that the transistor can switch on and off
    - Collector-Emitter Saturation Voltage (VCE(sat)): the minimum voltage drop from collector and emitter when the transistor is properly saturated.
    - Base-Emitter On-Voltage(VBE(on)): minimum voltage required between base and emitter to turn the transistor on
    - Collector-Emitter Breakdown Voltage (BVCEO): Voltage at which the reverse-biased collector-emitter junction fails
    Voltage Divider
    - Uses 2 Resistors to divide a larger voltage into a smaller one
    - Used to created a reference voltage
    - simple Schematic
    Vin ---+
           R1
    Vout --+
           R2
    GND ---+
    - the output voltage is determined by the ratio of the resistance of R1 and R2 according to the formula
    - Vout = Vin x (R2/ (R1+R2))
    - Vin is the input voltage
    - Vout is the output voltage between the 2 resistors
    - You can get any voltage between Vin and V0
    - Limited when it comes to supplying current to a load
    - Used only in high impedance loads or other circuits that draw minimal current
View all 5 project logs
  • 1
    Assembly
    Break panel from JLCPCB into both Control and Heater PCBs.
  • 2
    Soldering MCU
    Solder an ESP32-C3 Wroom 02 onto the controller board. The C3 Wroom 02 is only available in Standard PCBA instead of the cheaper Economic and I opted for cost saving.
  • 3
    Solder 4 male header pins
    Solder 4 header pins for the OLED display onto the bottom of the board.
View all 5 instructions
