1Assembly
Break panel from JLCPCB into both Control and Heater PCBs.
2Soldering MCU
Solder an ESP32-C3 Wroom 02 onto the controller board. The C3 Wroom 02 is only available in Standard PCBA instead of the cheaper Economic and I opted for cost saving.
3Solder 4 male header pins
Solder 4 header pins for the OLED display onto the bottom of the board.
4Install OLED
Place a 0.91" OLED on the bottom 4 headers
5Flash Code
Plug in a USB source and upload code
Gangwa Labs
