The Signet
BIG BROTHER IS WATCHING YOU...
Send him a message.
The Signet — A Morse Beacon for Protest Messaging / Video Steganography
The Signet is a small, WiFi configurable beacon designed to embed a message (encoded in Morse code) into recorded video footage using a blinking light source.
Designed and built with personal and operational security in mind, this device NEVER connects to any internet servers, NEVER stores any logs, and NEVER collects any information on the user.
https://github.com/Quiklearner2099/The_Signet
  Watch the complete 14-minute build tutorial to assemble your own Signet device:
Why this exists
📣 Durable speech when platforms fail
In many places, digital censorship and content suppression are rising. The Signet is built for situations where people need to communicate ideas in public— especially during peaceful demonstrations—without relying on platforms, audio, or live speech.
Instead of shouting a message (which can provoke instant confrontation or get drowned out), The Signet lets a message persist inside the footage itself—so it can be discovered later in recordings from participants, journalists, or fixed cameras. The point is durability: the message travels with the video.
The Signet uses standard International Morse Code (ITU), ensuring global readability and compatibility with both human and machine decoding. A message embedded in footage can’t be muted, algorithmically downranked, or “lost in the crowd” the same way a post can.
🧾 Footage continuity & tamper indication
The Signet can also be used as a continuity marker for recorded footage. By embedding a continuous, time-ordered Morse message into the recording, the signal should remain consistent from start to finish.
  • Unexpected gaps, jumps, or resets may indicate cuts, dropped frames, edits, or tampering.
  • This can help viewers and investigators spot continuity breaks that might otherwise go unnoticed.
How this differs from watermarking
While The Signet and watermarking both involve embedding information into video, they solve very different problems and operate in fundamentally different ways.
Watermarking
  • Added after recording during editing or encoding
  • Relies on digital pixel or compression manipulation
  • Usually invisible and algorithmic
  • Can often be removed or degraded through re-encoding
  • Primarily serves ownership and copyright enforcement
The Signet
  • Embeds information at the moment of recording
  • Uses optical signaling (visible or IR light)
  • Independent of codecs, platforms, and formats
  • Becomes part of the physical scene, not a digital layer
  • Can reveal edits through continuity breaks
Watermarking alters the media.
The Signet alters the scene.
Privacy & Security by Design
  • No app required — browser-based configuration only
  • No internet connectivity — never connects to cloud services
  • Temporary local Wi-Fi AP for configuration only
  • Automatic AP shutdown after 90 seconds of inactivity
  • No persistent logs or telemetry
  • Stateless by power design — power cycling resets to default
Ethical Use
The Signet is intended to support lawful, non-violent freedom of expression, documentation, and artistic or journalistic messaging. It must not be used to enable harm, harassment, intimidation, illegal activity, or to mislead people about what is being recorded or communicated.
The_Signet_Security_Brief_v1.3.0.pdf
Adobe Portable Document Format - 421.63 kB - 03/05/2026 at 22:29
Preview
The_Signet_QuickStart_Guide_v1.3.0.pdf
Adobe Portable Document Format - 582.09 kB - 03/05/2026 at 22:29
Preview
  • 1 × Seeed Studios XIAO ESP32 C6 U1 - Low-power RISC-V SoC that provides MCU and WiFi connectivity, built in antenna and USB-C Lipo charging. Cheap & small.
  • 1 × IR LED (850nm to 950nm) IR_LED - The Signet uses an NTD352818 (950nm) because it is used to illuminate scenes for security cameras.
  • 1 × WS2812b RGB LED RGB_LED - Because F Big Brother, that's why.
  • 1 × 2N3904 NPN Transistor Q1 - This is to drive the IR LED as the GPIO pin of the XIAO is not suitable to supply the required current. a 2N2222 or MOSFet would have actually be a better option.
  • 1 × Toggle Switch SW1 - The Signet uses a CANAL MR5-110-F5-BB-DP - Rocker Switch, measuring 8.5X14mm. This fits the hole in the 3D printable case.
View all 13 components
  • Why this came to be
    Mike Stewart02/25/2026 at 23:43 0 comments
    The inspiration for this project came from 3 places.
    • Firstly, I don't particularly enjoy being monitored everywhere I go.
    It takes something from you, even if you don't realize it. I grew up in an era where people weren't under 24/7 video surveillance and privacy was the default. Who are 'The Watchers'? What do they do with the footage? Is there really any way to know? I'm not foolish, I know that there is nothing I can do to stop it, but I don't have to accept it silently. If you're going to record me, then you're going to have to hear what I have to say. I was never consulted about it, so just as 'The Watchers' did, I have re-written the terms of the deal without asking.
    And there is nothing they can do about it.
    • Secondly, watching the Hong Kong protests in 2019/2020.
    These oppressed people literally having to protest with blank sheets of A4 paper without a voice after their government broke the terms and conditions. Some of these same people now protesting the London Mega Embassy in the UK in fear of the same violation. Thanks to dedicated YouTuber, Lewis Hand and his channel TeamTaiwanUK, live coverage has been available. This is where I noticed, people with cameras everywhere, security guards recording, police body cams, shadowy figures in the periphery recording the participants, surveillance cameras covering every angle.... Why, what for? Going to record me? Fine, but now your video is going to carry MY message for anyone to see.
    • Third and finally, online censorship.
    Social Media platforms are not the moral police at the behest of governments or corporations. This must be resisted at all costs. The Signet bypasses all known forms of automated keywork triggering and reporting based censorship.
    Stay tuned, more to come...
View project log
  • 1
    Build your Signet, send your message.
    Detailed build guide is HERE
View all instructions
Merlin wrote 03/06/2026 at 13:04 point
Although I share your concern and annoyance about surveillance, I wonder who will or can read the messages. I don't know morse, and would not know how to decipher the message you send in you various videos (I can imagine the type of messages though ;)
Is walking around with a sign on me reading "Fuck surveillance" not basically the same while reaching a wider audience?
Once the Signet gets wider acceptance, the riscs of protesting will be the same.
Mike Stewart wrote 03/06/2026 at 13:42 point
Merlin, these are really great points, and you're not wrong that a sign gets the message across loud and clear to everyone passing by!
The Morse code aspect is admittedly a bit of a barrier — but that's actually part of the point, and it's not as niche as it might seem. Right now in 2026, Chinese netizens are actively using Morse code encoded as emoji sequences to discuss topics banned on platforms like Weibo and WeChat. The automated censorship systems can't parse it, but the people who need to communicate can. It's a real, living example of exactly this idea in practice — hiding a meaningful signal inside something that looks like noise to The Great Firewall. These people, the Chinese, know a thing or two about censorship.
And it turns out the same principle holds here in the West too. I've actually tested The Signet's videos across several Western social media platforms, and so far the algorithms and flagging mechanisms have failed to detect or curtail the message being spread. The signal is invisible to moderation systems in exactly the same way the IR is invisible to the naked eye. That could change as platforms get smarter about it — but for now, it works.
The sign analogy is a fair one, but there's a key difference: a sign is loud, visible, and attributable to you *in the moment*. The Signet can transmit invisibly in IR — only capturable by a cameras — which means you can be in a crowd, at a protest, at a public event, and broadcasting a message that only those who know to look for it will find. There's no sign to confiscate, and nothing visible to point at.
As for wider acceptance raising the risk — you're absolutely right, and that's a tension worth sitting with honestly. The goal isn't to replace overt protest, but to add a layer that works *before* the crackdown, in environments where holding that sign could get you arrested or worse. Think of it less as a megaphone and more as a signal flare for people who already know what to look for.
And honestly? If it ever gets popular enough that authorities start worrying about it, that's a pretty good problem to have. 👍😄👍
I hope this gives you some food for thought, have a fantastic day!
Mike
Mike Stewart wrote 03/06/2026 at 13:44 point
One more thing Merlin...
Morse code is easy to learn. It's not hard at all. Give it a shot, it's kind of fun!
