Zilog Z80
Another legend from the 8-bit era, this processor powered the first portable computer as well as the beloved “Trash-80” Two years short of the Z80's 50th birthday, Zilog has called it curtains on the 8-bit MPU.
There are alternative solutionsare there. But to build a complete SBC or system based on Z80 requires additonal memory, decoder, UART, etc.,
SIMPLE Z80 SBC with 8kB ROM, 8kB RAM and UART
It is much easier to design and implement a Z80 SBC with ROM, RAM and UART all inside a FPGA using VHDL.
This project is based on the Aaron Brady's Z80 in the year 2016
The VHDL core used is T80 CPU which was created on Apr 21, 2002 by Daniel Wallner
SPECIFICATION:
- PROCESSOR: Z80
- PROGRAM MEMORY: 8kB
- SYSTEM RAM: 8kB
- COMMUNICATION: UART
- I/O PORT: 144, 145
The wrapper around Z80 can be seen at Gist
Z80 will have Microsoft BASIC V4.7b which fits into the 8kB ROM address space and the BASIC will use some memory in RAM for STACK, STATUS. The user program also goes into the RAM address space.
The VHDL project was compiled using both Quartus version 9.1sp2 and 18.1 and working properly. We can implement more RAM and ROM along with additional features using higher Logic Elements and internal RAM available from the same family.
TARGET BOARD:
- FPGA: EP4CE6E22C8N
- Logic Elements (LEs): 6,272
- PLLs: 2
- Embedded Memory: 276,480 bits
- I/Os: 91
- Package: 144-LQFP
- USB-to-Serial Interface: CH340C
- FPGA TX pin: PIN_10
- FPGA RX pin: PIN_23
- Clock Sources
- 50 MHz: PIN_24, PIN_25
- 27 MHz: PIN_90, PIN_91
- Push Buttons (Active-Low with Pull-Ups)
- FPGA Reset: PIN_88
- 4x User Buttons [3:0]: PIN_73, PIN_80, PIN_89, PIN_114
- LEDs (Active-Low)
- 5x LEDs [4:0]: PIN_1, PIN_2, PIN_3, PIN_7, PIN_11
- On-Board Storage
- Altera EPCS4N (Serial Configuration Device)
- Winbond 25Q64JVSIQ (64 Mbit / 8 MB Serial NOR Flash)
- Power Supply
- +5V via USB Type-C connector
- 4x AMS1117 LDO voltage regulators: +3.3 V, +2.5 V, +1.8 V, and +1.2 V outputs
- Bitstream Programming
- via a JTAG socket for USB Blaster
RTL:
After compiling the VHDL code we can see the RTL view
In the RTL view we can clearly see the main blocks used in the design such as T80 CPU, ROM, RAM, UART and IO.
If we init the ROM with BASIC V4.7b HEX file, then the HEX file will be automatically loaded into ROM and start running during configuration.
Onboard there are 2 clock sources available. 50 MHz(pin24/pin25) and 27 MHz(pin90/pin91). Each source connected to two clock input pins. We can use either one of them. In this case the clock connected to pin#24 which corresponds to 50 MHz input.
set_location_assignment PIN_24 -to clk set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to clk
The board used already having CH340C onboard. We just need to assign the Tx and Rx pins.
set_location_assignment PIN_23 -to rxd1 set_location_assignment PIN_10 -to txd1 set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to rxd1 set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to txd1
The system RESET is assigned to
set_location_assignment PIN_88 -to n_reset set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to n_reset
There are only 5 LEDs available onboard. Either we can use the onboard 5 LEDs or assign different pins for LEDs
set_location_assignment PIN_34 -to leds[0] set_location_assignment PIN_32 -to leds[1] set_location_assignment PIN_30 -to leds[2] set_location_assignment PIN_76 -to leds[3] set_location_assignment PIN_77 -to leds[4] set_location_assignment PIN_85 -to leds[5] set_location_assignment PIN_98 -to leds[6] set_location_assignment PIN_100 -to leds[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to leds[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to leds[6] set_instance_assignment...Read more »
mit41301
Michele Perla
