log entry #1 - XH7115C CNC rationalization
I have wanted a CNC machine since my first experience machining back in university with manual mills, lathes, and tapping machines. I have a degree in biomedical engineering with a mechanical focus in mechatronics and controls so I had the opportunity to learn how to use these and program these machines in school.
A couple years ago, I successfully convinced my employer to purchase a Genmitsu proverXL V2 table top CNC with the expansion kit. I set it up with a raspberry pi, a gcode sender, and a remote monitoring controller, and a jog pendant. I enjoyed building the machine and generating CAD/CAM but hated the raspberry pi-linux-cncjs aspect. I am not a linux person and the headless raspberry pi was a nightmare to setup/ navigate installs. I primarily used the CNC machine to create flat sheet fixtures for an inkjet silkscreen printer, a robot soldering machine, and an epoxy robot. All cool and valid reasons to machine stuff but none were exciting enough for me.
I have since left that company and now make enough $$$ that I was able to afford a home with a decent sized garage to fill with tools. I already own a lot of machinery like various 3D printers, a bench top laser, a mill, and lathe but I want to take things to the next level. Now, in my opinion, is the time to start expensive hobbies like CNC machining.
I looked for used machines nearby and found some good but expensive options. There were a couple tormach PCNC machines but both were listed for over $10,000 CAD and required work to get cleaned up and achieve sufficient accuracy. I came across several benchtop CNC machines like the makera carvera, genmitsu cubiko, nestworks C500, and the shariff DMC.
All of these above mentioned machines have a bad value proposition. The Shariff DMC2 mini costs approximately $4500 USD to have assembled by the factory which is on par with the Carvera and Carvera Air. For this price, you can buy the full sized XH7115C (VMC210C) CNC machine from China and have it shipped to your door with customs and duties paid. Of course, this is what I did and is also the topic of this project.
I want to cut metals and engineering plastics to make end use projects and molds for my other projects so i require a decent machine.
After some back and forth with the manufacturer, I decided to upgrade the VMC210C from factory with a 10 tool automatic tool changer (ATC), an iso20 spindle with a pneumatic drawbar, a GSK980MDc control system, and precision C5 ball screws for all axes. I could have also opted for the 4th axis but was near sighted at keeping costs down.
I saw this purchase as taking a huge risk with a new vendor on Alibaba which I had not vetted and had no way of feasibly knowing if I would actually receive the machine i wanted.
Well, the machine is real and arrived. This good news came just before Christmas so it was a welcomed surprise and holiday project.
Next log will discuss reception, unpacking, and first impressions. Stay tuned for real project work and convincing reasons to buy one yourself.
Austin MacDonald
Tim Wilkinson
3D Meister
Mike Volckmann
Joseph Eoff
