SN65HVD230 fix
02/15/2026 at 14:27 • 0 commentsQuick note how to fix SN65HVD230 can module:
I waste hours trying to figure out why my CAN setup doesn't work and only after I read f$% datasheet and check all voltages with multimeter I found that standby pin voltage is above 0.75 volts, that means manufacturer mistake.
After I short-circuit this resistor everything start working as it should, so if you have same module just desolder this resistor:
and short the pads together
I hope you reading this before hours of troubleshooting
Made Video Guide + 50A Stress Test
02/05/2026 at 13:40 • 0 comments
Aleksandr
